Thread Number: 47612
Maytag A606 Washer Leaking Oil |
Post# 691255 , Reply# 1   7/22/2013 at 22:10 (3,902 days old) by DigAPony ()   |   | |
Most likely the transmission o-ring seal. Unfortunately, the repair involves major disassembly of the machine and trans to replace the seal. There are several threads on the available on the subject. |
Post# 691338 , Reply# 2   7/23/2013 at 06:58 (3,901 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Keep using the machine till it dies, you may have to clean the motor and main drive pulleys every few years and replace only the main drive belt if the machine starts to have problems while pumping out water and accelerating into spin. The machine will keep working for years this way and while oil leaks are common on MT washers as they age it is seldom the death of them and I dough that 1 in a 100 ever get fixed. |
