Thread Number: 47879
A real "plain Jane" Maytag HOH dryer |
Post# 694881   8/7/2013 at 12:52 (3,907 days old) by polkanut (Wausau, WI )   |   | |
If you're a no frills BOL kind of person, this one is for you. Exterior shots show a nice looking machine, and for $20 it's yours. Located in Wausau, WI. CLICK HERE TO GO TO polkanut's LINK on Wausau Craigslist This post was last edited 08/07/2013 at 16:51 |
Post# 694892 , Reply# 1   8/7/2013 at 14:22 (3,907 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 694909 , Reply# 2   8/7/2013 at 14:59 (3,907 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 694910 , Reply# 3   8/7/2013 at 15:01 (3,907 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 694925 , Reply# 5   8/7/2013 at 15:30 (3,907 days old) by runematic (southcentral pa)   |   | |
Post# 694927 , Reply# 6   8/7/2013 at 15:37 (3,907 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 694929 , Reply# 7   8/7/2013 at 15:41 (3,907 days old) by Kenmore71 (Minneapolis, MN)   |   | |
It is a DE90. This was considered to be the BOL, so much so that I have no brochures on it. I do have parts lists, however. The interesting thing is that this dryer did everything that a DE306 did. It even used the same timer. Unlike earlier low-end halo of heat dryers that sported a galvanized zinc drum, this dryer used the same porcelain drum that even the 806 & 906 used! This dryer was manufactured from 1969 until 1976 when it was replaced with its "big load" replacement, the DE91. Also this model was only offered in electric. If you wanted a gas low-end dryer you had to move up to the DG306. |
Post# 694956 , Reply# 8   8/7/2013 at 16:54 (3,907 days old) by polkanut (Wausau, WI )   |   | |
