Thread Number: 47946
Another Speed Queen Repair? |
Post# 695438 , Reply# 1   8/9/2013 at 21:58 (3,905 days old) by cfz2882 (Belle Fourche,SD)   |   | |
pop the front panel off and look for leak evidence-could be as major as a main seal or simple as a leak at the pressure switch fitting. |
Post# 695801 , Reply# 4   8/11/2013 at 09:31 (3,904 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 695803 , Reply# 6   8/11/2013 at 09:34 (3,904 days old) by mtn1584 (USA)   |   | |
have you checked or changed the inlet hoses, and their connections? Mike |
Post# 695841 , Reply# 7   8/11/2013 at 12:38 (3,904 days old) by mrb627 (Buford, GA)   |   | |
Post# 695855 , Reply# 8   8/11/2013 at 13:49 (3,903 days old) by Yogitunes (New Jersey)   |   | |
well, first I would check it out myself, and most likely fix it........
but for the most part, I would still investigate, to let the repair man know when and how the water is getting on the floor.... a certain cycle or water temp/level setting...a particular load that was being done...when exactly did the water show up..... Repairmen usually charge by the hour....he can run every single cycle trying to find the issue.....or you can help him along and get right to the possible cause.... work with him.....not against him..... offer him a bottle of chilled water or snack as well....it will go a long way! watch it be a small 5.00 part you could have replaced yourself...... |
Post# 695861 , Reply# 9   8/11/2013 at 14:17 (3,903 days old) by mrb627 (Buford, GA)   |   | |
Post# 696318 , Reply# 12   8/13/2013 at 20:30 (3,901 days old) by angus (Fairfield, CT.)   |   | |
Sink checks out no drain pipe leak - but as I mentioned the only place that was dry was under the sink. Not sure how the water didn't make it there... Oh, well.... |
Post# 696348 , Reply# 13   8/14/2013 at 01:04 (3,901 days old) by alr2903 (TN)   |   | |
Oh NO, Anthony. I know we both suffered the Amana leaking center seal syndrome. I hope it is an inexpensive repair. Arthur |
Post# 696549 , Reply# 14   8/14/2013 at 20:38 (3,900 days old) by angus (Fairfield, CT.)   |   | |
Well, at least if it is the main tub seal, it happened this time after 7 years instead of 2 years with the Amana. |
Post# 696657 , Reply# 15   8/15/2013 at 14:24 (3,899 days old) by mtn1584 (USA)   |   | |
Don't forget to let us know. Mike |
Post# 696720 , Reply# 16   8/15/2013 at 20:40 (3,899 days old) by angus (Fairfield, CT.)   |   | |
Friday afternoon is the scheduled service appointment. We will see... |
Post# 696981 , Reply# 18   8/16/2013 at 21:50 (3,898 days old) by mtn1584 (USA)   |   | |
A cracked drain hose!! Hooray, but seriously, I am glad it's not a major repair, and all Speed Queen owners can breath a collective sigh of relief! MIKE |
Post# 697012 , Reply# 19   8/17/2013 at 00:04 (3,898 days old) by alr2903 (TN)   |   | |
Anthony, I am glad it was nothing extremely serious. Arthur |
