Thread Number: 47986
Water pump |
Post# 696464 , Reply# 1   8/14/2013 at 13:36 (3,905 days old) by DaveTranter (Central England)   |   | |
I'm fairly sure that someone on here will have a spare valve, Bunty... If all else fails, post photographs of the old one and we can probably make you one... Enjoy your twintub Dave T |
Post# 696498 , Reply# 2   8/14/2013 at 15:55 (3,905 days old) by sesteve (London, UK)   |   | |
Hi Bunty
Should be quite easy to fix. It might have stuck rubber cups. It you are quite handy you could take the pump out by disconnecting the 3 hoses, the connecting rod to the knob, take off the belt and remove the 3 screws from underneath and lift the pump out. There is a wire clip going over the pump body. Remove this - it is a bit tricky and then the pump will separate into two. In the top half you will see the cups and you can check that they have not become detached or stuck to the body - I've attached a link showing the new cups for reference in case you need to replace. When you put the pump back together make sure the o ring is nice and clean and in the right place. Hopefully that should solve it Cheers Steve :) CLICK HERE TO GO TO sesteve's LINK |
Post# 696506 , Reply# 3   8/14/2013 at 16:22 (3,905 days old) by ozzie908 (Lincoln UK)   |   | |
