Thread Number: 48233
Early 1990's Whirlpool Washing Machine Adding Fabric Dispenser |
Post# 699095 , Reply# 1   8/26/2013 at 19:08 (3,888 days old) by SawaSun ()   |   | |
Second picture of washing machine. |
Post# 699101 , Reply# 2   8/26/2013 at 19:19 (3,888 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Yes there is a dispenser available for that machine. It will cost around $12 at an appliance parts store. All you have to do is take off the cap and put the dispenser in. You do this by finding the notch around the top of the agitator, inserting a small flathead screwdriver and prying the cap loose. You can then press the dispenser in until you hear it lock in place. It is important when doing this to reach down the middle of the agitator and make sure the cover over the dog mechanism is seated in place. If not FS solution will get in and stop it from working.
When using any loiqid FS dispenser it is important to only use a small amount and fill the rest of the space with hot water to prevent a buildup of old softener and mold. Also a couple quarts of hot water poured through the dispenser regularly will help keep it clean. I hope this answers your question. WK78
Post# 699123 , Reply# 3   8/26/2013 at 20:12 (3,888 days old) by DADoES (TX, U.S. of A.)   |   | |
Whirlpool Part Number 63580 should do the trick for you. Here a source $9.94 with $6.50 shipping. Softener Dispenser |
