Thread Number: 48283
Hoover 455 (A3072) Washer Overhaul Pt 2 |
Post# 699661 , Reply# 1   8/29/2013 at 02:47 (3,884 days old) by crouzet951 ()   |   | |
This also included the rusty drain tube. |
Post# 699663 , Reply# 2   8/29/2013 at 02:49 (3,884 days old) by crouzet951 ()   |   | |
Black Hammerite is being applied to both flanges, and some miscellaneous exterior locations. |
Post# 699666 , Reply# 4   8/29/2013 at 03:03 (3,884 days old) by crouzet951 ()   |   | |
The motor parts ready to go back together. The repairer painted the field windings red when re-baking them. The motor now has a racing stripe. Hehe. |
Post# 699667 , Reply# 5   8/29/2013 at 03:04 (3,884 days old) by crouzet951 ()   |   | |
The commutator came up very well. |
Post# 699673 , Reply# 9   8/29/2013 at 03:39 (3,884 days old) by crouzet951 ()   |   | |
The screws, nyloc nuts, and washers, are stainless steel. The screws are the same size as the screws used to attach the backplate to the outer drum. |
Post# 699674 , Reply# 10   8/29/2013 at 03:42 (3,884 days old) by crouzet951 ()   |   | |
As can be seen, the screw length is irrelevant. |
Post# 699675 , Reply# 11   8/29/2013 at 03:43 (3,884 days old) by crouzet951 ()   |   | |
The heating element cleaned up very well using some kettle decalcifier. |
Post# 699677 , Reply# 13   8/29/2013 at 03:51 (3,884 days old) by crouzet951 ()   |   | |
Can you guess what these are? More op art? |
Post# 699679 , Reply# 14   8/29/2013 at 03:55 (3,884 days old) by crouzet951 ()   |   | |
The old paint was stripped off (now that is a pleasant experience), KURUST to the rust, sanded and cleaned, then two coats of primer and two top coats. They came up quite well. |
Post# 699682 , Reply# 17   8/29/2013 at 04:29 (3,884 days old) by crouzet951 ()   |   | |
That's all for now. I'll be back tomorrow with the conclusion. Cheers John |
Post# 699765 , Reply# 18   8/29/2013 at 14:09 (3,884 days old) by sesteve (London, UK)   |   | |
