Thread Number: 48305
Hoover 455 (A3072) Washer Overhaul Pt 3 |
Post# 700040 , Reply# 1   8/30/2013 at 19:37 (3,890 days old) by crouzet951 ()   |   | |
It begins... |
Post# 700041 , Reply# 2   8/30/2013 at 19:40 (3,890 days old) by crouzet951 ()   |   | |
A new anti-twist suspension kit was installed. |
Post# 700043 , Reply# 3   8/30/2013 at 19:41 (3,890 days old) by crouzet951 ()   |   | |
Replacing the weight. New nyloc nuts were used. |
Post# 700044 , Reply# 4   8/30/2013 at 19:44 (3,890 days old) by crouzet951 ()   |   | |
The drum ready to go back into the cabinet. The old rubber bands on the dampers trick worked a treat. |
Post# 700045 , Reply# 5   8/30/2013 at 19:45 (3,890 days old) by crouzet951 ()   |   | |
Success! |
Post# 700046 , Reply# 6   8/30/2013 at 19:46 (3,890 days old) by crouzet951 ()   |   | |
I bought some multi-purpose grease and it's blue! |
Post# 700048 , Reply# 7   8/30/2013 at 19:49 (3,890 days old) by crouzet951 ()   |   | |
The cleaned up drum and backplate ready to install. The thermostat was treated to a new seal. |
Post# 700051 , Reply# 9   8/30/2013 at 19:59 (3,890 days old) by crouzet951 ()   |   | |
The newly painted upper rear support was installed. |
Post# 700052 , Reply# 10   8/30/2013 at 20:01 (3,890 days old) by crouzet951 ()   |   | |
Installing the detergent dispenser, water inlet solenoids, and hoses. |
Post# 700054 , Reply# 11   8/30/2013 at 20:03 (3,890 days old) by crouzet951 ()   |   | |
Installing the door seal onto the cabinet lip. |
Post# 700058 , Reply# 13   8/30/2013 at 20:11 (3,890 days old) by crouzet951 ()   |   | |
Installing the freshly repainted door. I had previously installed and adjusted the door without the drum installed (much easier), and used a whiteboard marker to mark the positions of the hinges. |
Post# 700060 , Reply# 14   8/30/2013 at 20:13 (3,890 days old) by crouzet951 ()   |   | |
Connect the hoses after one final look around, and gingerly pull the control knob. |
Post# 700071 , Reply# 19   8/30/2013 at 20:41 (3,890 days old) by crouzet951 ()   |   | |
I took the opportunity to reconnect the original drain hose from the machine, which was retrieved from my parents' house the week-end before. |
Post# 700080 , Reply# 23   8/30/2013 at 21:41 (3,889 days old) by crouzet951 ()   |   | |
Some more images before closing the machine up. The new module guard turned out well. |
Post# 700081 , Reply# 24   8/30/2013 at 21:44 (3,889 days old) by crouzet951 ()   |   | |
All looks good down here. Two more holes were drilled in the wire support to allow another cable tie for the thermostat wires. |
Post# 700082 , Reply# 25   8/30/2013 at 21:45 (3,889 days old) by crouzet951 ()   |   | |
Everything looks OK. |
Post# 700083 , Reply# 26   8/30/2013 at 21:47 (3,889 days old) by crouzet951 ()   |   | |
Before the rear panel is attached. |
Post# 700085 , Reply# 27   8/30/2013 at 21:49 (3,889 days old) by crouzet951 ()   |   | |
One last look inside from the front. There is supposed to be a suppressor on the rear upper panel, but the new one hasn't arrived yet. |
Post# 700086 , Reply# 28   8/30/2013 at 21:50 (3,889 days old) by crouzet951 ()   |   | |
From the rear with the back panel and lid installed. |
Post# 700087 , Reply# 29   8/30/2013 at 21:51 (3,889 days old) by crouzet951 ()   |   | |
Manufactured in February 1979. |
Post# 700090 , Reply# 30   8/30/2013 at 21:54 (3,889 days old) by crouzet951 ()   |   | |
To complete the olde worlde installation, new hoses were made from bulk hose using the original brass fittings. As can be seen, it's now running on hot and cold water |
Post# 700137 , Reply# 33   8/31/2013 at 01:14 (3,889 days old) by mrprojectionist ()   |   | |
Fantastic! A great job! |
Post# 700144 , Reply# 34   8/31/2013 at 02:12 (3,889 days old) by electron1100 (England)   |   | |
Post# 700155 , Reply# 36   8/31/2013 at 05:17 (3,889 days old) by hotpoint95622 (Powys)   |   | |
Post# 700157 , Reply# 37   8/31/2013 at 07:02 (3,889 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
John, congratulations on a great restore and for taking the time to show the complete process, its a labour of love with any of these machines getting them up and running again - has the Bosch been retired ?
Cant get over how good the motor looks for a strip down and paint job - glad to hear its working as it should... What next - matching dryer on top? |
Post# 700293 , Reply# 38   8/31/2013 at 20:22 (3,889 days old) by ronhic (Canberra, Australia)   |   | |
Post# 700492 , Reply# 40   9/1/2013 at 19:22 (3,888 days old) by optima (Cumbria England)   |   | |
Post# 700621 , Reply# 41   9/2/2013 at 12:41 (3,887 days old) by sesteve (London, UK)   |   | |
Hey John
This restoration has been fantastic and hope you are really pleased with the result. The thread has been like the Haynes manual for repair but much much better and in colour too. Well done and love the fact it has its original drain hose. That's one of my pet subjects lol Happy washing in it Steve :) |
Post# 700650 , Reply# 42   9/2/2013 at 15:21 (3,887 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 701185 , Reply# 44   9/4/2013 at 16:19 (3,885 days old) by supermaticjames (Donegal, Ireland)   |   | |
Congratulations on your big restoration job I'm proud of your patience, labour and effort! |
Post# 701304 , Reply# 45   9/5/2013 at 01:52 (3,884 days old) by mattywashboy (Perth, Western Australia)   |   | |
Post# 701913 , Reply# 47   9/8/2013 at 02:54 (3,881 days old) by crouzet951 ()   |   | |
As mentioned before, I have some old matchbox washer wiring looms, so it was easy to make up a couple of correctly coloured leads with the proper insulators. |
Post# 702111 , Reply# 49   9/8/2013 at 19:07 (3,881 days old) by optima (Cumbria England)   |   | |
Post# 703724 , Reply# 53   9/17/2013 at 18:35 (3,872 days old) by crouzet951 ()   |   | |
Hoover 195 image 2 |
Post# 703725 , Reply# 54   9/17/2013 at 18:36 (3,872 days old) by crouzet951 ()   |   | |
Hoover 195 image 3 |
Post# 703727 , Reply# 55   9/17/2013 at 18:40 (3,872 days old) by crouzet951 ()   |   | |
Hoover 195 image 4 Sorry folks, looking at the plate on the back it appears the dryer was made in New Zealand, and the model no is D6034. I should look at my own images before posting. Hehe. |
Post# 703819 , Reply# 56   9/18/2013 at 05:46 (3,871 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 703827 , Reply# 57   9/18/2013 at 06:52 (3,871 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 703828 , Reply# 58   9/18/2013 at 06:54 (3,871 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 703846 , Reply# 59   9/18/2013 at 09:13 (3,871 days old) by gizmo (Victoria, Australia)   |   | |
I'm pretty sure those NZ made Hoover dryers are actually Fisher and Paykel. |
Post# 704216 , Reply# 61   9/20/2013 at 08:01 (3,869 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 704220 , Reply# 62   9/20/2013 at 08:09 (3,869 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 704241 , Reply# 63   9/20/2013 at 10:58 (3,869 days old) by electron1100 (England)   |   | |
Post# 834422 , Reply# 65   7/29/2015 at 17:30 (3,192 days old) by mikeymatic (Manchester UK)   |   | |
Just read your posts on your 455 refurb from a couple of years ago - what a fantastic job you've done.
Is it still going strong ? I've just started on a Hoover Logic A3670 - it's my first big overhaul - your posts have given me lots of inspiration and motivation, and some great tips. Would love to hear how the 455 is doing, being a fan of Hoover Washing Machines and Oz ! Mike. |
Post# 1160374 , Reply# 66   9/25/2022 at 11:40 (577 days old) by chetlaham (United States)   |   | |
Post# 1160488 , Reply# 67   9/27/2022 at 03:43 (575 days old) by Ricky5050 (Durham Britain)   |   | |
Hi when changing a timer take lots of photos from all angles. And draw a simple diagram of needed. Some times the cables are on blocks which is easier as they often only fit one way. Some are lord of wires. Some don’t need to come off until after the timer is or I’ve bridging wires so leave them until the timers out and on a bench
Good luck |
