Thread Number: 48595
MAH7550AAW Diag code 6 |
Post# 704250 , Reply# 1   9/20/2013 at 11:56 (3,868 days old) by redcarpetdrew (Fairfield, CA)   |   | |
I'm assuming that this is a version of the MAH7500AWW washer that I have, a Neptune washer with touch screen controls WITHOUT a 'Get A Life' window in the door.
I believe you have a bad motor/motor control. What serial number is it? Diag code 6 is recognizing that the upper control is looking for motor movement and not sensing it thru the lower board and help 41 is basically the same, not seeing the tachometer sending rpm and direction.There is a kit for the older machines that upgrades the system to a MUCH better motor and control board. It's well worth it. Usually, you can tell by looking at your old motor control board (mounted in the bottom of the cabinet, on the right hand side). There is a fuse that might be blown and/or a fried triac or I.c. Sometimes not but they still quietly die. The upper control communicates with the motor control to check status of the motor and if it's spinning before unlocking the door. Since your lower board is most likely dead, the upper will not unlock the door... Part number of the conversion kit is 12002039 and is very easy to install. Do the belt while you're at it. 12001788 is the belt. Let us know. You can also club email me for help if you need to. Anything I can do to help keep a version of one of the best washers Maytag made 'on the road'... RCD This post was last edited 09/20/2013 at 16:05 |
