Thread Number: 48596
Asko Dryer Help!! |
Post# 704222 , Reply# 1   9/20/2013 at 08:12 (3,862 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 704251 , Reply# 2   9/20/2013 at 12:06 (3,862 days old) by dj-gabriele ()   |   | |
Is the drum motor on a starting capacitor? If yes it might have blown and the motor has difficulties starting to turn |
Post# 704252 , Reply# 3   9/20/2013 at 12:16 (3,862 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 704356 , Reply# 4   9/20/2013 at 23:41 (3,861 days old) by ian_p61 (Melbourne Australia)   |   | |
It's not the belt I checked that will check the capacitors! Thanks All |
Post# 704580 , Reply# 5   9/22/2013 at 07:32 (3,860 days old) by ian_p61 (Melbourne Australia)   |   | |
I have taken the dryer completely apart (so dusty) and I am pretty sure it s the capacitor on the motor, as if I turn the drum by hand when humming sometimes you would get movement, will be going tomorrow to asko for a new capacitor ( which model/one do. Ask for? Thanks all |
Post# 704643 , Reply# 6   9/22/2013 at 14:46 (3,860 days old) by dj-gabriele ()   |   | |
Simply take the old one with you and ask for one which has the same uF (microfarad) and V (voltage) rating. |
Post# 704884 , Reply# 7   9/23/2013 at 13:51 (3,859 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
If it is overheating EVERYBODY how said it could be the belt was ablsolutley wrong. These Asko's are pretty close to the EU standard and on every EU home dryer the Motor is directly connected to the fan EXCEPT the heatpump Mieles with there 2 Motors. So if the belt would have failed, the drum would stay straight while the fan turns... |
Post# 705680 , Reply# 8   9/27/2013 at 12:20 (3,855 days old) by hooverzodiac12 (Melbourne, Australia)   |   | |
