Thread Number: 48614
Zanussi & Tricity Bendix water solenoid |
Post# 704408   9/21/2013 at 10:48 (3,863 days old) by servisslimline (England, Brighton & Hove)   |   | |
Hi all, a few years ago i mentioned that my Zanussi FLA1002W took in fabric conditioner early, i was told it could be a faulty inlet but after investigation ive worked out its not possible, the inlet only has one feed as its cold so does not have a separate one direct to the softener compartment, ive noticed my Tricity Bendix AW1053W started to do the same thing recently. water only trickles into the compartment while filling through the proper compartment also but still manages to fill the chamber up and dispense the softener by the end of the 1st rinse fill. i just cant work out why! anyone got any ideas? if it is the inlet at fault however its a £20+ job which i want to avoid, as im hoping to sell the Zanussi in a few weeks time.
Phil |
Post# 704495 , Reply# 2   9/21/2013 at 17:38 (3,863 days old) by hotpoint9534 (UK)   |   | |
Yes indeed, the FLA1002W does have the mechanical link. See the link below for a parts diagram. Tom CLICK HERE TO GO TO hotpoint9534's LINK |
Post# 704579 , Reply# 3   9/22/2013 at 07:28 (3,863 days old) by servisslimline (England, Brighton & Hove)   |   | |
had a crack at sorting the problem and it seemed to work, there was an adjustable arrow thing which was set at a triangle with -1, -2, -3 on the left and +1,+2, +3 on the right so i set it at -1 and all seems well, cant believe it was that simple! wish id had a look a long time ago!
thanks all! phil |
