Thread Number: 48734
Kenmore/Whirlpool front load washer |
Post# 705867 , Reply# 1   9/28/2013 at 07:04 (3,856 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
When does the error appear? Right from the start or at the first drain? Sounds like a blocked or broken pump. Let him check if the pump still makes noises. If yes, he will need to remove the lower front panel (if it is splitten) and clean the pump filter... |
Post# 705881 , Reply# 2   9/28/2013 at 08:29 (3,856 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 705981 , Reply# 3   9/28/2013 at 18:57 (3,856 days old) by brucelucenta ()   |   | |
Thank you folks, it was indeed the pump trap plugged up. |
