Thread Number: 48751
Help! Kenmore TT #22401- 7 flashes.. 'clean' ? |
Post# 706065   9/29/2013 at 07:05 (3,855 days old) by stainfighter (Columbia, SC)   |   | |
Paging all who work on dishwashers...our '05 Kenmore TT -model 22401- is throwing code -7 flashes- on the 'clean' light...it pauses then repeats code. Didn't notice it, of course, until time to run it :-0. I cut the power to it, waited a minute, then cut power back on. Still flashes, so...
Is the control board toast? Or, is it a clogged pump? something else? Any advice is greatly appreciated before a) scheduling service, or b) replacing Thanks in advance! Robert |
Post# 706098 , Reply# 1   9/29/2013 at 12:02 (3,855 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
The electronic control has detected no temperature rise during the wash cycle. You can clear the memory and try running it again, press the high temp. option button, then air dry, then high temp. again, then air dry, within 10 seconds. If you enter the test cycle properly all LEDs should come on and the DW will run a short test cycle and clear the memory. Many of these DWs have had heater failures, look for cracks or blisters on the heater. I have also had bad door switches cause this problem as all stainless steel units have dual door switches and one switch controls only the heater. There should be a tech sheet attached to the back of the kick plate that will have more info. Good luck, Jeff |
Post# 706267 , Reply# 3   9/30/2013 at 05:42 (3,854 days old) by stainfighter (Columbia, SC)   |   | |
Thanks so much, Jeff, the directions you provided to me...spot on! After several minutes the board reset. It did not run a cycle though...I was home so I ran a full cycle, it ran fine. Nothing appears wrong with the heater coil... So for now we'll stay the course. Matt, agree with you, electronics can leave something to be desired....modern stuff spends half its time doing Gee-wiz/sensing la la la, when old school gets it done without fuss. Robert |
Post# 706277 , Reply# 4   9/30/2013 at 06:22 (3,854 days old) by Frigilux (The Minnesota Prairie)   |   | |
