Thread Number: 48771
Kitchenaide/Hobart KD-11 Questions |
Post# 706510 , Reply# 3   10/1/2013 at 02:51 (3,853 days old) by rocknrollohio ()   |   | |
Pull the hose from the tub to the drain valve and check for debris or broken glass, look twice because sometimes you don’t notice the clear broken glass pieces |
Post# 706522 , Reply# 5   10/1/2013 at 07:11 (3,853 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Matt, the drain solenoid should shut off at the end of the complete cycle and each time the machine needs to drain when it is running a cycle, however even if you open the door while the machine is washing the solenoid stays energized so the wash or rinse water will not run down the drain. You should check to see if the solenoid is just getting stuck or if it is actually energized when the DW is at the end of the cycle, that way you could tell if you have an electrical problem or a mechanical one.
Note to rocknroll, there is no hose between the drain valve and the pump on KD10s-KD14s, but it could have something caught in the drain valve seat area, more likely is that the drain valve seat area is just worn and not sealing well any longer. |
