Thread Number: 48928
kitchenaid energy saver v superba by hobart deluxe edition wont drain |
Post# 708622 , Reply# 1   10/11/2013 at 14:19 (3,848 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 708645 , Reply# 2   10/11/2013 at 16:07 (3,848 days old) by barcoboy (Canada)   |   | |
If I'm not mistaken, this looks like a KDS-20. I don't know if the KDS-20 uses the same drain valve as the KDS-18, but on my 18, you can really hear the snap of the drain valve when it opens and closes. Do you remember hearing a snapping sound when your dishwasher was working and draining properly, and if so, is it still snapping like that now? If it did, and it is not now, check for a broken wire at the valve, and if the wiring is okay, check to see that the timer is sending power down to the valve.
If the dishwasher is only partially draining, are you able to empty it completely by starting a cycle, then immediately pushing the Cancel/Drain button? (Might take a couple of tries to completely empty.) If so, this indicates a blockage somewhere in the drain line, or if the line is clear, the drain impeller itself might be partially broken. |
Post# 708684 , Reply# 3   10/11/2013 at 18:46 (3,848 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 708962 , Reply# 4   10/13/2013 at 07:26 (3,847 days old) by quincyman (Oldsmar, FL)   |   | |
I had the same problem with an earlier model. Wouldn't drain all the way-dishes weren't coming out clean. I pulled the wash arm out and then the filter. The filter was all clogged up. Scrubbed it in the sing and put back in the machine-problem solved. |
Post# 709210 , Reply# 5   10/14/2013 at 05:39 (3,846 days old) by chachp (North Little Rock, AR)   |   | |
Turned out it was a kinked hose under the sink so it was a real easy fix. In my case I have an odd configuration under my sink. The good news is I have a separate trap for the dishwasher which means it doesn't drain through my disposal. The bad news is it's such an odd set up that I think when the hose gets warm over time it must have just kinked. I didn't think it was in a position where this could happen but it did. I just moved things around a bit and the problem was solved.
This actually brings up a question I was going to ask anyway. Given my odd setup I was wondering if one of those ribbed hoses would work because they seem to bend better without kinking. However, I thought I read in one of these posts that those ribbed hoses should not be used on the older Kitchen Aid Dishwashers. Am I imagining that or is it true? |
Post# 709344 , Reply# 7   10/14/2013 at 18:54 (3,845 days old) by chachp (North Little Rock, AR)   |   | |
Post# 709414 , Reply# 8   10/15/2013 at 07:39 (3,845 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I agree with Steve's comments, it was very important to use the proper drain hoses on KA DWs, especially on the KD-20s and earlier.
One of the BIGGEST service problems that KA had with their DWs was poor draining caused by undersized drain systems and overly restrictive air-gaps. KA brought a lot of these problems upon themselves because they were the only DW maker that did not supply a drain line with the purchase of a new DW, most installers tried to just use the drain line from the old DW being removed and in the case of GE DW for example they used a drain line that was too small for a KA DW. KA DWs did not come with a drain line included till the KD 24 models came out.
KA was loosing a ton of money on warranty calls by the early 1980s because of drainage problems and claims for damage to porcelain door liners and tanks. They also had plenty of problems with the wall ovens and cook-tops they were selling after KA bought the Chambers line. It is one of the main reasons that KA sold out to WP, the company needed much better cost controls and management for the consumer side of the business. |
Post# 710399 , Reply# 9   10/20/2013 at 06:22 (3,840 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I have been summoned by the Great Dr. Bombay of the Hobart Inter Galactical Universe to post some pics of my KDS-20 Fill Levels.
This post was last edited 10/20/2013 at 06:37 |
Post# 710403 , Reply# 10   10/20/2013 at 06:42 (3,840 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 710404 , Reply# 11   10/20/2013 at 06:46 (3,840 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
