Thread Number: 49046
HELP! looking for parts for this 1970s Hotpoint |
Post# 710231 , Reply# 1   10/19/2013 at 14:49 (3,813 days old) by epixstar128 (toledo)   |   | |
Are you sure the motor is bad on the unit |
Post# 710278 , Reply# 2   10/19/2013 at 18:09 (3,813 days old) by akronman (Akron/Cleveland Ohio)   |   | |
the motor itself, if it is bad, should have all the numbers/ratings/RPMS/model# needed right on it even if no info exists on the overall dishwasher model.
This is the Hotpoint version of the late 60's GE Mobile Maid. Search this site for Mobile Maid for lots of info.
Your machine overall looks very nice. I just restored a 1966 GE and I am thoroughly impressed with its performance.
Other pro's here can advise on motor testing, but don't despair. GE made a zillion such motors
Post# 710511 , Reply# 4   10/20/2013 at 23:14 (3,812 days old) by akronman (Akron/Cleveland Ohio)   |   | |
mine did the same thing at first. Unplug the machine, stick your fingers up inside the bottom of the motor and try turning it by hand a bit. That's all it took to free up mine. If you have a relay problem, that's another story and I don't know how to check them, only replace when needed.
Have you yet found various ratings and stamped ID information on the motor? |
Post# 710544 , Reply# 5   10/21/2013 at 07:07 (3,811 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This DW uses a completely different pump and motor than yours does Mark, this one has the horizontal shaded pole motor that GE used forever. The thing that often happened to this pump and motor is it would get stuck if they sat too long unused. you can try freeing it by putting your fingers in the fan and turning it CW [ machine off and unplugged ] when looking and the end of the motor where the wires come out, if it is hard to turn and them breaks loose and then turns freely it may work just fine.
The nice thing about this style pump and motor is you can even substitute a new much more efficient GE pump and motor that uses just one third the power and is far quieter. |
Post# 710545 , Reply# 6   10/21/2013 at 07:11 (3,811 days old) by akronman (Akron/Cleveland Ohio)   |   | |
