Thread Number: 49057
Hitachi Twin Tub PS128-P |
Post# 710384 , Reply# 1   10/20/2013 at 04:06 (3,812 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Welcome. If I could buy a new Panasonic twintub I would, but the only place I find them sold is Kuwait.
My Electrofrigiwhite FL reverses by timer command to the motor module. Whereas in classic Maytags and GEs the timer directly switches the motor windings. Or the module can do it itself. So there is more than one way to do this. I don't know how the Hitachi reverses electrically. But the module has no mechanical failure points, if it goes wonk it's more likely to quit altogether. While the timer has mechanical contacts any one of which can fail. The bad news is, many appliance parts get orphaned at 7 years. You may have to settle for one direction. My 1973 Panasonic only ran one direction and that never caused a problem. |
Post# 710390 , Reply# 2   10/20/2013 at 05:28 (3,811 days old) by twinniefan (Sydney Australia)   |   | |
Hi Dave these do appear sometimes on ebay,although you need it to ne near where you live.
If you like twin tubs, you can get a Haier 6kg,(which I own) and apparently the company called Palsonic have just released 2 new models on the market one is 6.5kg and the other is a very large 8kg model. I believe there is another 6 or so kg model around but I cannot recall who the manufacturer is. Hope this helps you. Cheers. Steve. |
Post# 710439 , Reply# 3   10/20/2013 at 12:02 (3,811 days old) by cfz2882 (Belle Fourche,SD)   |   | |
timer could be at fault-this presuming your machine uses a split capacitor motor for the agitator/impeller where there are 3 wires and power is applied to one side or the other of the capacitor for each direction. |
Post# 710519 , Reply# 4   10/21/2013 at 00:37 (3,811 days old) by ronhic (Canberra, Australia)   |   | |
