Thread Number: 49100
Replacement pump for Maytag A2MP |
Post# 710999 , Reply# 1   10/23/2013 at 07:22 (3,831 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Maytag never made a substitute pump for these washers, but if you look long enough you may find a good used one or even a new one that someone happens to have.
Two possible alternatives would be to gravity drain the machine if there is a floor drain in the area where the machine is to be used, Maytag actually made these washers without drain pumps for users that had floor drains. Ironically the WP is one of the weak parts of MT AMP style washers, MT never had a decent WP till they came up with the plastic Poly-Pump on their Helical Drive machines and then they had the best WP in the industry.
The other alternative would be to use an electric drain pump from something like a post 1996 GE TL washer, after you mount it you could wire the two power leads to the brake solenoid so the pump would only run when the washer is spinning.
Good Luck with your project and keep us posted, John. |
Post# 711014 , Reply# 2   10/23/2013 at 08:47 (3,831 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 711021 , Reply# 3   10/23/2013 at 09:40 (3,831 days old) by dnastrau (Lords Valley, PA)   |   | |
What is wrong with the pump? Maybe it can be repaired (?) |
Post# 711168 , Reply# 5   10/24/2013 at 07:18 (3,830 days old) by dnastrau (Lords Valley, PA)   |   | |
Maybe something like this could be retrofitted... CLICK HERE TO GO TO dnastrau's LINK on eBay |
Post# 711174 , Reply# 6   10/24/2013 at 09:00 (3,830 days old) by quiggsdj ()   |   | |
Thanks - that's the kind of thing I had in mind. |
