Thread Number: 49162
Well I've got it apart, now what? |
Post# 711688 , Reply# 1   10/27/2013 at 13:31 (3,805 days old) by kowidge ()   |   | |
It appears that it was leaking a little (Sorry a little blurry) |
Post# 711715 , Reply# 2   10/27/2013 at 16:29 (3,805 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 711763 , Reply# 3   10/27/2013 at 21:23 (3,805 days old) by DigAPony ()   |   | |
That is probably the biggest concern, could be the result of a leaking tub stem seal. Check for signs of water stains on top of the transmission. |
Post# 711774 , Reply# 4   10/27/2013 at 23:20 (3,805 days old) by kowidge ()   |   | |
There were no signs of water stains on top of the transmission, it was pretty clean. |
Post# 711824 , Reply# 5   10/28/2013 at 07:17 (3,804 days old) by beekeyknee (Columbia, MO)   |   | |
Hi Tony,
This may be TMI, but there's lots of good info and it will keep you busy for awhile. I hope it helps. Click the back button, type 18261 in the search box at the top of the page and click search. Click the second result titled "The Imperial Forum 2008 Archives". A new tab will open. Now you're in the Archives. Scroll down to 18261, click and read. Click the back button and scroll up to the top. Click <--Return To Archive Index. Click 2009 in Imperial and scroll down to 22088 and read. Click back, scroll down to 22830, scroll down to reply # 15 (First things first) and read. Click back and scroll down to 25520, click and read. Click back and scroll up to top. Click <--Return To Archive Index and click 2010 in Imperial. Scroll down to 27599 and read. Click back and scroll up to top and click <--Return to Archive Index. Click on 2011 in Imperial, scroll down to 32963 and read. Click back, scroll down to 34701 and read Click back, scroll to top and click <--Return to Archive Index. Click 2012 in Imperial, scroll down to 38712 and read. Watch video if you want. Close video tab. Click back, scroll down one line to 38714, click and read. Watch video if you want. Close video tab. Scroll down to Reply # 180 and click link. Read link then close tab. Click back, scroll down to 41351 and read. Click back, scroll up to <--Return To Archive Index. Click 2013 in Imperial, scroll down to 45624 and read. Old water valves can be taken apart to check for rust and worn parts or you may just want to replace it if faulty. Brian |
Post# 711826 , Reply# 6   10/28/2013 at 07:19 (3,804 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
That stain may just be the sudsy water that can dribble down from the tub cover from over sudsing or it may be a leak at the U shaped injector hose where the fresh water comes in the washer, in any case it is NOT a serious problem that would be real difficult to fix.
The white corrosion on the insides of the cabinet is not a problem at all, Maytag's galvanized cabinets behave this way when they get damp or wet repeatedly.
The motor rollers should be lubricated if they look dry, you can spray silicone lubricant on them or give them a little squirt of turbine oil, it does not really matter. Be sure the main drive belt is in good condition and with the motor pulled forward and that the pump belt is VERY loose when holding the motor, otherwise the machine will have no chance of agitating and spinning well. Unless the pump belt looks terrible don't bother buying a new one it will not work any better with a new pump belt, but the main drive belt is important, if you need a new one be sure to buy one made for a MT washer, it will have the MT Pt# on the belt, we have even been having good luck with the generic belts made for MT. John L
Post# 712061 , Reply# 8   10/29/2013 at 08:35 (3,803 days old) by kowidge ()   |   | |
I don't know what to look for.... |
Post# 712064 , Reply# 10   10/29/2013 at 08:49 (3,803 days old) by kowidge ()   |   | |
John, I replaced the belts and they are as you say they should be in thickness and looseness. |
Post# 712218 , Reply# 11   10/30/2013 at 09:00 (3,802 days old) by beekeyknee (Columbia, MO)   |   | |
Hi Tony,
I guess you're talking about the top flange of the tub where the tub top slides down inside it. I use emery cloth or paper instead of steal wool. Steel wool might work, but it will flake off bits of steel, of course. As far as epoxy, I use JB Weld. Get the two tube kind. One tube is black (steel) and the other tube is red (hardener). Mix two equal parts of each and mix with a toothpick on a piece of cardboard. You'll have about 10 min. working time. Apply with your finger, wipe off your finger, wet your finger with spit and smooth the Weld down. If you need more spit you can use some more fingers. Let dry 24 hours before messing with it. It dries fastest at room temp. You can get an almost perfect surface this way. Then you don't have to sand it later. You probably already knew about JB Weld, but you might not have known about the spit trick. That's a neat little thing I learned from my Mom from her 40 years of refinishing furniture. She's used it on other types of finishes before. Water might work, but I like spit better. There's more working time with spit and it doesn't run. If you're not going to disassemble the whole machine, I'd give that tub bearing a shot of turbine oil with a hypo syringe and an 18 gauge needle (pink base). It will probably suck up 6 to 8 cc's of it. Have you got your agitator off yet. You can tell the condition of the drive shaft, mounting stem and gauge the overall cleanliness of the machine and what it might look like between the tub and the basket by looking under the agitator. It should come off every couple of years or so to be cleaned, inspected and have Vaseline applied to the drive shaft. This post was last edited 10/30/2013 at 09:33 |
Post# 713122 , Reply# 12   11/4/2013 at 11:59 (3,797 days old) by AtomicT (Middletown, NY)   |   | |
By they way, I'm the same Tony, just now a full member with a new username!
And third, after the second load, the crevices around the top of the drain pump had water sitting in them. There was no indication of water dripping from the bleach tank or the tub, nor from the clam-shell seam going around it. All the hex-head screw heads had rusted up prior (but not the threads once I extracted them)to sitting, but if the seal was broken, would water end up there? I'm very confused as I have no idea how water got there.. It's a flat sided O-ring, about 14-1/4" inch I.D., but it doesn't seem to be available. Is this pump repairable?
I found this one eBAY and it seems like less $$$ than the others. Is it any good (i.e. cheap quality)?
This is the last thing, then I can finally move it upstairs! Woohoo!
-Tony CLICK HERE TO GO TO AtomicT's LINK on eBay |
Post# 713124 , Reply# 13   11/4/2013 at 12:05 (3,797 days old) by AtomicT (Middletown, NY)   |   | |
Just wanted to say thanks to all of you as well for getting me interested in this, and thanks for all your help and advice. I did just about all the stuff I was advised to, (not all, but close to it and will do the rest in the future), and would not have had the inclination to even give it a try if it weren't for the wealth of help and knowledge on this site! |
Post# 713136 , Reply# 14   11/4/2013 at 13:03 (3,797 days old) by rp2813 (Sannazay)   |   | |
Post# 713211 , Reply# 15   11/4/2013 at 18:35 (3,797 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 713218 , Reply# 16   11/4/2013 at 19:16 (3,797 days old) by Washman (o)   |   | |
that is one fine machine, a relic of when American manufacturing really meant something. |
Post# 713226 , Reply# 17   11/4/2013 at 19:32 (3,797 days old) by jimmler (Nipomo, CA)   |   | |
Post# 713228 , Reply# 18   11/4/2013 at 19:40 (3,797 days old) by stainfighter (Columbia, SC)   |   | |
Post# 713435 , Reply# 19   11/5/2013 at 20:12 (3,796 days old) by AtomicT (Middletown, NY)   |   | |
Although its a lot like most of the stuff I own, looks great inside and out, but never really works the way I want. I still love it, but my wife is always driving it.
Anyways, I couldn't find an o ring to replace the old one, so I had to order one. I'll hold onto the old one just in case..... So Saturday I can finally move it upstairs. |
Post# 713446 , Reply# 20   11/5/2013 at 21:46 (3,796 days old) by stainfighter (Columbia, SC)   |   | |
Post# 714847 , Reply# 21   11/12/2013 at 11:21 (3,789 days old) by AtomicT (Middletown, NY)   |   | |
Thank you all for all the encouragement, well wishes, especially all the tech advice. Its in and woo boy - it works magnificent. Quiet, clothes are clean, and the ambiance heightened.
Glad I joined this group!
ps, the dryer will be added later. Have to run a new duct and reinstall the plug, both relocated by previous owner. |
Post# 714867 , Reply# 22   11/12/2013 at 13:31 (3,789 days old) by rp2813 (Sannazay)   |   | |
That is a lucky washer to have found such a perfect home, and yours is a lucky household to have found a top of the line version of the best, most expensive washer money could buy at the time it was manufactured. Settle in to enjoy many years of the "thrum thrum" sound of heavy duty, high quality workmanship. |
