Thread Number: 49163
Maytag 641C dryer |
Post# 711698   10/27/2013 at 14:56 (3,805 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711700 , Reply# 1   10/27/2013 at 15:14 (3,805 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711701 , Reply# 2   10/27/2013 at 15:16 (3,805 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711702 , Reply# 3   10/27/2013 at 15:17 (3,805 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711703 , Reply# 4   10/27/2013 at 15:19 (3,805 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711706 , Reply# 5   10/27/2013 at 15:52 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711708 , Reply# 6   10/27/2013 at 15:54 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711709 , Reply# 7   10/27/2013 at 15:55 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711710 , Reply# 8   10/27/2013 at 15:58 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
You can see some lint did fall into the heater coils and was baked.
This post was last edited 10/27/2013 at 18:21 |
Post# 711711 , Reply# 9   10/27/2013 at 16:00 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
This might be the reason why the lint got in the coils. Hope I can find a replacement.
Post# 711712 , Reply# 10   10/27/2013 at 16:05 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711756 , Reply# 11   10/27/2013 at 21:03 (3,804 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 711845 , Reply# 12   10/28/2013 at 09:13 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711847 , Reply# 13   10/28/2013 at 09:16 (3,804 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711864 , Reply# 14   10/28/2013 at 11:09 (3,804 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 711866 , Reply# 15   10/28/2013 at 11:27 (3,804 days old) by swestoyz (Cedar Falls, IA)   |   | |
Hey guys -
One quick heads up on the gasket (312238) you previously mentioned. In 1966, the HOH dryers received a re-designed door gasket, which is not compatible on the 1965 and earlier 641/700 HOH series dryers. The earlier gasket kit (302448) was discontinued even before Whirlpool bought out Maytag. You might want to check an older Maytag dealer in your area. They may have a few still collecting dust in their parts rack. That's how I found a few for myself. Thankfully you can still find the front and rear felt seals fairly easily. Good luck! (Quick note for the archives - the lower end pre-66 HOH dryers (models with the single piece door) use a completely different gasket than the two piece HOH models, AND the water dryers uses two different gaskets all together depending on model! Crazy stuff. Maytag had enough sense by 1966 to use the same gasket on all dryer models, up until the Stream-of-Heat Big Load dryers.) CLICK HERE TO GO TO swestoyz's LINK |
Post# 711869 , Reply# 16   10/28/2013 at 12:00 (3,804 days old) by bluejay (Havre de Grace, MD)   |   | |
The 2nd link appears to be 302448 (or a compatible version). I had ordered a 312238 and it fit, but honestly it did not work as well, so I popped the old door gasket back on. What amazes me is that parts still appear to be plentiful for the A700, but the DE700/701 seem to have most parts listed as NLA. Go figure, right?
Post# 711933 , Reply# 17   10/28/2013 at 16:38 (3,803 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711939 , Reply# 18   10/28/2013 at 17:39 (3,803 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 711955 , Reply# 19   10/28/2013 at 19:16 (3,803 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 711965 , Reply# 20   10/28/2013 at 20:09 (3,803 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 712835 , Reply# 21   11/2/2013 at 19:30 (3,798 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 712836 , Reply# 22   11/2/2013 at 19:30 (3,798 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 712946 , Reply# 23   11/3/2013 at 10:30 (3,798 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 712988 , Reply# 24   11/3/2013 at 15:17 (3,797 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 713239 , Reply# 26   11/4/2013 at 19:56 (3,796 days old) by maytag63 (South Berwick, Maine)   |   | |
Yes, they are correct. These are the ones I purchased
http://www.ebay.com/itm/171103463469QUES... http://www.ebay.com/itm/181196544217QUES... |
Post# 713329 , Reply# 28   11/5/2013 at 07:39 (3,796 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You have the correct belts, when properly installed the shorter of the two belts goes from the idler pulley to the drum pulley, the longer belt from the motor, blower and around the large part of the idler pulley, this larger belt should be very loose, the shorter drum drive belt very tight. If your dryer still has the aluminum motor pulley try to find a replacement motor pulley, MT changed from the fast wearing aluminum motor pulleys on the later HOH dryers to steel pulleys to reduce slippage and performance problems. |
Post# 714426 , Reply# 29   11/10/2013 at 17:38 (3,790 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 714427 , Reply# 30   11/10/2013 at 17:40 (3,790 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 714431 , Reply# 31   11/10/2013 at 17:44 (3,790 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 714435 , Reply# 32   11/10/2013 at 17:49 (3,790 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 714473 , Reply# 33   11/10/2013 at 20:47 (3,790 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 714533 , Reply# 34   11/11/2013 at 06:14 (3,790 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 714811 , Reply# 35   11/12/2013 at 06:47 (3,789 days old) by dnastrau (Lords Valley, PA)   |   | |
It looks great! Did you have any luck locating a new door gasket? |
Post# 714828 , Reply# 36   11/12/2013 at 09:34 (3,789 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 714975 , Reply# 37   11/12/2013 at 21:45 (3,788 days old) by dnastrau (Lords Valley, PA)   |   | |
I wonder if these folks could provide a gasket that would work for the door... CLICK HERE TO GO TO dnastrau's LINK |
Post# 715132 , Reply# 38   11/13/2013 at 16:44 (3,787 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 716097 , Reply# 39   11/18/2013 at 17:19 (3,782 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 716099 , Reply# 40   11/18/2013 at 17:21 (3,782 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 716100 , Reply# 41   11/18/2013 at 17:24 (3,782 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 716125 , Reply# 42   11/18/2013 at 19:38 (3,782 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Maytag recommends painting the lower inside of the heater shroud with Hi-Temperature silver paint to reduce the chance of coins etc shorting out the heater. I do not know how good it does but it sure makes the shroud look great.
Look up the thread where I restored a DE750 a year or so ago where I did this. |
Post# 716145 , Reply# 43   11/18/2013 at 21:14 (3,782 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 716160 , Reply# 44   11/19/2013 at 00:06 (3,782 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Post# 717095 , Reply# 45   11/22/2013 at 16:49 (3,778 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 717112 , Reply# 46   11/22/2013 at 17:43 (3,778 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 717279 , Reply# 47   11/23/2013 at 13:51 (3,778 days old) by Dimitris (greece)   |   | |
Post# 717297 , Reply# 48   11/23/2013 at 17:45 (3,777 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 717361 , Reply# 49   11/24/2013 at 05:02 (3,777 days old) by Dimitris (greece)   |   | |
Post# 717378 , Reply# 50   11/24/2013 at 09:14 (3,777 days old) by mrb627 (Buford, GA)   |   | |
Post# 719935 , Reply# 53   12/8/2013 at 13:15 (3,763 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 719936 , Reply# 54   12/8/2013 at 13:16 (3,763 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 719937 , Reply# 55   12/8/2013 at 13:18 (3,763 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 720001 , Reply# 56   12/8/2013 at 19:33 (3,762 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 720026 , Reply# 57   12/8/2013 at 21:08 (3,762 days old) by maytag63 (South Berwick, Maine)   |   | |
Thanks John. I did read about that in one of the threads. Is this one an upgrade?
http://m.ebay.com/itm/140782704750QUESTI... |
Post# 720050 , Reply# 58   12/9/2013 at 05:11 (3,762 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 727069 , Reply# 60   1/11/2014 at 20:31 (3,728 days old) by maytag63 (South Berwick, Maine)   |   | |
Well now that the holidays are over, I once again continued with the dryer. Replaced the motor pulley and converted the dryer to 110-120 so I could see if it would run. It did, but one items that didn't work was the timer. It would not advance. Nor will the bell ring when I advanced it to off. So, need to find a replacement timer. Interesting that the time housing itself is missing the model number. I can't, so far, remove the screw in the front of the dial. It's stuck. Maybe it's there.
I did pull the timer itself. Maybe I can just replace that. This post was last edited 01/11/2014 at 21:05 |
Post# 727187 , Reply# 61   1/12/2014 at 12:14 (3,728 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 727191 , Reply# 62   1/12/2014 at 12:34 (3,728 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 727192 , Reply# 63   1/12/2014 at 12:35 (3,728 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 727193 , Reply# 64   1/12/2014 at 12:37 (3,728 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 730495 , Reply# 66   1/25/2014 at 17:57 (3,714 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 730506 , Reply# 67   1/25/2014 at 19:18 (3,714 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 740661 , Reply# 68   3/9/2014 at 12:04 (3,672 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 740663 , Reply# 69   3/9/2014 at 12:05 (3,672 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 740664 , Reply# 70   3/9/2014 at 12:06 (3,672 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 740667 , Reply# 71   3/9/2014 at 12:14 (3,672 days old) by maytag63 (South Berwick, Maine)   |   | |
If you increase the settings of the video to HD it looks better. The clothes I used were dry. Wanted to use them as props.
CLICK HERE TO GO TO maytag63's LINK |
Post# 740668 , Reply# 72   3/9/2014 at 12:15 (3,672 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 740669 , Reply# 73   3/9/2014 at 12:17 (3,672 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 740681 , Reply# 74   3/9/2014 at 14:03 (3,672 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 740780 , Reply# 76   3/9/2014 at 18:50 (3,671 days old) by maytag63 (South Berwick, Maine)   |   | |
Hi Will, I cross referenced and found that this part would work on my 641C. I don't know if this one would fit your dryer. I do have a continuing search on E-bay for the correct part / # . Someday I might be lucky.
Post# 741787 , Reply# 77   3/14/2014 at 09:02 (3,667 days old) by classiccaprice (Hampton, Virginia)   |   | |
