Thread Number: 49262
Neptune Dryer won't heat |
Post# 712920   11/3/2013 at 06:41 (3,819 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 712933 , Reply# 1   11/3/2013 at 08:37 (3,819 days old) by YoGiTuNeS (New Jersey)   |   | |
Jerry...is this electric?.....could be the relay not kicking in....most likely something simple.....were gonna need John or Drew to anwswer this one for us
are you still having issues with the washer as well? I just got a stacked unit, I know you were having issues, and didn't want to get you upset, I just had to do a bearing job, and a good cleanout, and so far running smooth....got it for a song, but was in pieces, miracle I got it all back together... these ones are a little complicated to get into, built a little different than the stand alone units...I have the gas dryer... |
Post# 712934 , Reply# 2   11/3/2013 at 08:41 (3,819 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 712943 , Reply# 3   11/3/2013 at 10:01 (3,819 days old) by YoGiTuNeS (New Jersey)   |   | |
I know on the TL stacked set I have, there was the heat relay not clicking 'on'...20.00 later, it works...
problem is looking up where its located at on these units....theres a control board in the upper right corner of the dryer, as well as units behind the control panel.... check your schematics....for help with locating it.... check all connections as well to make sure they are snug |
Post# 712945 , Reply# 4   11/3/2013 at 10:17 (3,819 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 712950 , Reply# 5   11/3/2013 at 10:47 (3,819 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 712952 , Reply# 6   11/3/2013 at 11:05 (3,819 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Probably most likely thing is a bad heater element, but it could be one of about 10 other things. The good news is that there is no computer that controls the heat and no heater relay, it could also be a burnt wire at the junction block, bad timer, temperature switch or thermostat and even a bad motor centrifugal switch, You are just not having much luck with Maytag Laundry Appliances Jerry.
We figure that more than 1/3 of our total repair income still comes from repairing MT appliances, the Maytag Man was anything but lonely during the last 15+ years of MTs existence and is why MT stopped using the Old Lonely theme in their ads toward the end of their existence. |
Post# 713011 , Reply# 7   11/3/2013 at 17:17 (3,819 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 715675 , Reply# 8   11/16/2013 at 09:45 (3,806 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 715679 , Reply# 9   11/16/2013 at 10:33 (3,806 days old) by DigAPony ()   |   | |
That is a good idea, but first wet your finger, then grab onto a nearby water pipe with the other hand just to be extra sure.. |
Post# 715682 , Reply# 10   11/16/2013 at 10:59 (3,806 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 715683 , Reply# 11   11/16/2013 at 11:10 (3,806 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
maybe you should consider replacing your washer and dryer even if its something we do not like to consider there is a time where appliance are beyond repair and must be replace and if you consider replacement here is a link
Post# 715763 , Reply# 12   11/16/2013 at 21:08 (3,806 days old) by redcarpetdrew (Fairfield, CA)   |   | |
