Thread Number: 494
Plastic GE woes! |
Post# 49019 , Reply# 1   11/11/2004 at 02:18 (7,103 days old) by fixerman ()   |   | |
If "new" means pre 1995,the brake is inside the transmision. Usually the detent sticks or otherwise breaks. The trans needs to come out to repair it. You will Probably have to replace the trans. |
Post# 49036 , Reply# 2   11/11/2004 at 15:07 (7,102 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Speaking of trans replacements,we had some new style GE washers come through the shop a few years ago,that leaked through the center.Even with new center seals installed. Finally talked to a GE tech,who said if they still leak with new center seals,the transmission needed to be replaced,with one with an oversize shaft. Sound familiar to anyone? kennyGF |
