Thread Number: 49646
Miele De Luxe T 355 or T 347 K ??? |
Post# 717600   11/25/2013 at 09:25 (3,804 days old) by Dimitris (greece)   |   | |
First I found the T 355 which is vented that I prefer but used....
Now the T 347 K came along which is even older and unused!!! Same price for both.... However, the T 347 K is a condenser.... I am so confused... Which would you go for!!!? www.ricardo.gr/buy/spiti-diakosmi... www.ricardo.gr/buy/spiti-diakosmi... CLICK HERE TO GO TO Dimitris's LINK |
Post# 717620 , Reply# 1   11/25/2013 at 10:59 (3,804 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
The T347K is a water cooled condenser dryer. It needs a water connection just like a washing machine and will use quite a big amount of water for one load to dry. If water is expensive, this is not a good idea. Considering this, it's no surprise that it wasn't used.
Just for the record, K models are water cooled condenser dryers, C models air cooled. The first air cooled Miele dryer was launched about the same time, it was the T368C. |
Post# 717679 , Reply# 2   11/25/2013 at 16:55 (3,803 days old) by Dimitris (greece)   |   | |
Post# 723401 , Reply# 3   12/27/2013 at 14:25 (3,771 days old) by ruffiana ()   |   | |
Good evening, is it possible to have the instruction of the T347K is a water cooled condenser dryer. if not could you explain me the symbols?Thank you in advance.paola |
Post# 723439 , Reply# 4   12/27/2013 at 17:06 (3,771 days old) by brisnat81 (Brisbane Australia)   |   | |
Going Clockwise around the dial Extra Dry Normal + (Mixed Loads) Normal Hand Iron Machine Iron Cool down Anti crease Timed Dry Cool Down |
Post# 723443 , Reply# 5   12/27/2013 at 18:08 (3,771 days old) by Dimitris (greece)   |   | |
Ciao Paola, finalmente io ho comprato l' altro modelo, T355.
Si puo andare in negozio di Miele per comprare il manual per T 347 K. E nuova per lay? Vorei vedere ancora altre fotografie per favore.... Quanto tempo fa per un ciclo? La mia e fantastica, sono contentisimo!!!! Pero non poso controlare la temperatura dei programmi,. La tua ha un button per regolare la temperatura, vero? Grazie, dimitris |
