Thread Number: 49724
AEG Lavatherm 720 shutting down? |
Post# 718694   12/1/2013 at 15:10 (3,792 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
So guys...this is one of my "daily drivers" in the winter. The last couple of loads I have done, when I pass by the dryer, it is no longer tumbling, but the pump (for the condensation) is still running. Also...the dryer is extremely hot.
So I take out the water reservoir, open the door and let things cool down (20 mins), then it works again. Any ideas? |
Post# 718741 , Reply# 1   12/1/2013 at 20:41 (3,792 days old) by kitty ()   |   | |
Your dryer is overheating. The motor drives the drum and the blower. Either the electrical connection is loose or the motor has shorted in the windings. |
Post# 719049 , Reply# 2   12/3/2013 at 17:21 (3,790 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 719054 , Reply# 3   12/3/2013 at 17:26 (3,790 days old) by ozzie908 (Lincoln UK)   |   | |
Also it may be a good idea to remove all filters and give them a scrub with hot water and dish soap or do what I do and stick them in the dishwasher :o) I have been known to put the condenser in the DW as well if really gunged up. You may want to see if the stats in the filter area need a wipe to remove build up as that can cause the issues you are experiencing.
Austin |
Post# 719159 , Reply# 4   12/4/2013 at 04:31 (3,790 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 719196 , Reply# 5   12/4/2013 at 09:35 (3,789 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 719355 , Reply# 6   12/5/2013 at 04:26 (3,789 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
