Thread Number: 49844
Minty! GE electric stove |
Post# 720014   12/8/2013 at 20:15 (3,788 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
70's vintage. Were I not a gas stove man I'd be all over it. WK78 CLICK HERE TO GO TO whirlykenmore78's LINK on Minneapolis Craigslist |
Post# 720018 , Reply# 1   12/8/2013 at 20:28 (3,788 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
An update of the J 370 I have. I copied the photos and blew them up, and I can see that while this one does not have Sensi-Temp, it does have Coil Select, re-named Power Saver. It's the same selectable coil size idea, so that you can heat a 4-inch, 6-inch or full 8-inch area of the burner.
I cannot tell if the range uses trim rings with separate burner bowls, or if it uses the updated one-piece bowl. I'm also unable to tell for sure if it has a light for the cooktop, but it looks as if it might. I say someone needs to visit the Cities and get this baby! P.S.: Double-check the color - ad says White, photo looks like possible Almond. |
