Thread Number: 49932
KitchenAid model info |
Post# 721126   12/14/2013 at 09:07 (3,778 days old) by jimmler (Nipomo, CA)   |   | |
Greetings and pre Happy Holidays!
Negotiating a deal with a locally owned KitchenAid Superba. I asked the owner to supply a model number, but I don't know where to tell them to look. All they said was it's a Superba Monterey 21. Is this a Hobart produced unit? Where would the official model/serial number be located so I can instruct them where to look? I'm enclosing a pic if that will help ID it. Thanks for any help! -Jim |
Post# 721127 , Reply# 1   12/14/2013 at 09:34 (3,778 days old) by Kenmore71 (Minneapolis, MN)   |   | |
That is an early transitional machine, probably about 1988. It was made after WP acquired Kitchenaid but the guts of that machine are ALL the Hobart/Kitchenaid design that essentially dates back to the 18 series from 1976.
The one change that WP made was to add considerably more insulation to quiet the machines down, thus the moniker "WhisperQuiet" on the panel. |
Post# 721133 , Reply# 2   12/14/2013 at 10:34 (3,778 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 721197 , Reply# 4   12/14/2013 at 14:39 (3,778 days old) by Kenmore71 (Minneapolis, MN)   |   | |
The KDS-21 was introduced by Hobart in April of 1984. Whirlpool acquired Kitchenaid in January of 1986 after a somewhat prolonged legal battle. When was the Monteray introduced into the KD-21 lineup? It's my understanding that the Monteray was mechanically identical to the KDS-21 it just had a sleeker trim package (read "no fake woodgrain!")
Post# 721241 , Reply# 5   12/14/2013 at 20:09 (3,778 days old) by jimmler (Nipomo, CA)   |   | |
Post# 721372 , Reply# 6   12/15/2013 at 22:47 (3,777 days old) by jimmler (Nipomo, CA)   |   | |
Post# 721373 , Reply# 7   12/15/2013 at 22:49 (3,777 days old) by jimmler (Nipomo, CA)   |   | |
Post# 721374 , Reply# 8   12/15/2013 at 22:50 (3,777 days old) by jimmler (Nipomo, CA)   |   | |
Post# 721375 , Reply# 9   12/15/2013 at 22:53 (3,777 days old) by jimmler (Nipomo, CA)   |   | |
Post# 721377 , Reply# 10   12/15/2013 at 22:58 (3,777 days old) by jimmler (Nipomo, CA)   |   | |
Some staining on the door. Haven't really tried to do any cleaning. It was too late in the day to really fiddle with it. Underneath looks good, tho. No water stains like it had been leaking. The control panel area needs a good cleaning and the selection buttons stick. The CANCEL button won't release any depressed buttons. I didn't figure it was gonna be a plug and play machine, tho, so I'm not disappointed. It does have the bituminous felt in addition to a sound blanket wrapped around it. Even tho I wash most of my dishes by hand, I think this is going to be a great addition to the kitchen. Will keep you posted of any progress.
-Jim |
Post# 721414 , Reply# 11   12/16/2013 at 08:35 (3,776 days old) by DADoES (TX, U.S. of A.)   |   | |
Cancel doesn't release the buttons directly, it's a cycle unto itself that advances the timer to the last drain increment, then probably to run the drying blower (without heat) for one increment, then off. The buttons release when the handle is raised. If the machine is at "normal" off at end of a cycle, Cancel will run through the timer advance / drain sequence and off again. |
