Thread Number: 50074
Little Giants electrics.... |
Post# 723048 , Reply# 1   12/25/2013 at 09:22 (3,767 days old) by eronie (Flushing Michigan)   |   | |
ground and neutral are connected to the same buss bar in my circuit panel. stove is 4 prong, dryer is 3 prong . |
Post# 723056 , Reply# 2   12/25/2013 at 09:49 (3,767 days old) by Yogitunes (New Jersey)   |   | |
maybe this will help you....no wiring conversion of any type required, get the version of plug you need, and in seconds, your all set....
shop online, or any electic warehouse should have them.......PlugPro 3 to 4 conversion......theres also a 4 to 3.....for either the dryer, or the stove.... other than that, the only choice is to change the cord.....or change the outlet... CLICK HERE TO GO TO Yogitunes's LINK |
Post# 723057 , Reply# 3   12/25/2013 at 09:51 (3,767 days old) by chetlaham (United States)   |   | |
Do not I repeat do not run a dedicated ground rod. It will do nothing for safety. Being able to get an impedance low enough to generate enough current to trip a breaker via a standard 8 foot ground rod is difficult if not impossible. One would need exceptionally low soil resistance or many, many deeply driven rods to get a low enough resistance. Even then that may not be enough if the transformer neutral isn't grounded well enough through the soil on the other side. Hence why it isn't allowed in the NEC. If a fault did occur in the oven chances are the ground rod would become energized. The rod will end up passing current continuously which will start to dry up the soil around it; if there are any flammable materials near by (such as dry brush or leaves) the dryness and heat can start a fire. The stove will still be a shock hazard if a fault occurred within it sine the rod may not give equal potential to the other ground reference points (ie refrigerator or sink plumbing)
What the stove needs is bonding with the buildings equipment grounding/bonding system. If all you need are 2 phases and an equipment grounding conductor as long as 3 wires are present then your all set on the stove side. All that's needed is to know what is going on the other side of the cable feeding the range outlet. |
Post# 723062 , Reply# 4   12/25/2013 at 10:41 (3,767 days old) by chetlaham (United States)   |   | |
