Thread Number: 50086
Need help with maytag A50 |
Post# 723061 , Reply# 1   12/25/2013 at 10:19 (3,772 days old) by kitty ()   |   | |
I forgot to say one thing else. The spinner sounds like it has a loose belt. I mean the motor starts up then the spinne accelerates. Thank you in advance for your reply. |
Post# 723070 , Reply# 2   12/25/2013 at 11:24 (3,772 days old) by Yogitunes (New Jersey)   |   | |
keep in mind, an empty spinner running will 'whistle' air thru the holes at high speed, a few TLers will do the same thing when empty...
when I worked at a shop, if it didn't whistle, there was something wrong.....not always, but something to keep in mind.... it is possible of a loose/worn belt....that goes also for the springs for tension for the pump.... |
Post# 723086 , Reply# 3   12/25/2013 at 13:57 (3,772 days old) by kitty ()   |   | |
I also was thinking the same about the belt. If something is in the spinner, it doesn't whistle. But if I put a plastic bag in it, it will stop the noise. Thank you for your response. |
Post# 723165 , Reply# 5   12/26/2013 at 07:26 (3,771 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 723230 , Reply# 7   12/26/2013 at 16:54 (3,770 days old) by kitty ()   |   | |
It looks like the spinner's seal is leaking... the big question is ... can it be fixed? |
Post# 723353 , Reply# 9   12/27/2013 at 10:08 (3,770 days old) by kitty ()   |   | |
OH NO THE SPINNER'S DRUM SEAL IS LEAKING. CAN I FIND A NEW ONE? |
Post# 723363 , Reply# 10   12/27/2013 at 10:46 (3,770 days old) by kitty ()   |   | |
Yeah. The belt is SERIOUSLEY loose. |
Post# 723366 , Reply# 11   12/27/2013 at 11:12 (3,770 days old) by kitty ()   |   | |
Dirty interior of machine |
Post# 723369 , Reply# 12   12/27/2013 at 11:16 (3,770 days old) by kitty ()   |   | |
Rusted spinner motor Also, look at the inside of the motor. |
Post# 723558 , Reply# 13   12/28/2013 at 17:51 (3,768 days old) by hippiedoll ( arizona )   |   | |
hey kitty!!
did you see that there are a few maytag twin tub parts listings (from the same seller, i think?) on ebay right now?? here is a link for one of the motors. i don't know which one you need but they have both motors up right now and also it looks like the whole spinner can side's parts. ebay link: http://www.ebay.com/itm/Vintage-Maytag-A... |
Post# 723562 , Reply# 14   12/28/2013 at 18:01 (3,768 days old) by kitty ()   |   | |
... But I ONLY need the seal, not the motor, but it could use a new one. The motor is rusted, but I think it should last a while. I have seen motors FAR more rusted than that. |
Post# 723572 , Reply# 15   12/28/2013 at 19:02 (3,768 days old) by hippiedoll ( arizona )   |   | |
if you plan to keep & use that maytag A50 for quite a while, it doesn't hurt to have extra "spare" parts with you, for those "just in case" moments that we never think about & dread, when they do happen.
i know with my hoover 0510 twin tub, when i bought belts, i bought more than one and hoses, i only bought one (washtub to drain pump) cuz that was all i could find. but me & my way of thinking is, may as well buy what you can find right now cuz who knows if you will be able to find it again, later on down the line. especially with vintage or any twin tubs, since they are no longer being made here in the united states. but this is just my way of thinking. if you decide to go for them spare parts, good luck, i hope you get what you need (& "extras"). ;o) |
Post# 723684 , Reply# 16   12/29/2013 at 14:19 (3,768 days old) by kitty ()   |   | |
That motor doesn't look right for my machine. I can always improvise for a part. Thank you for your time. The motor (on my machine) is in so-so condition. |
Post# 723757 , Reply# 17   12/29/2013 at 22:11 (3,767 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 723774 , Reply# 18   12/30/2013 at 00:12 (3,767 days old) by hippiedoll ( arizona )   |   | |
here is the ebay link for the spinner parts from the same seller. maybe you can make an offer for just the part you need? or you can buy the whole lot to have the extra "spare" parts:
http://www.ebay.com/itm/Vintage-Maytag-A... and here is the other motor they have listed as well. maybe this is the motor like your's: http://www.ebay.com/itm/Vintage-Maytag-A... |
Post# 723821 , Reply# 19   12/30/2013 at 07:29 (3,767 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
