Thread Number: 50127
Unimatic questions |
Post# 723412 , Reply# 1   12/27/2013 at 15:26 (3,771 days old) by christfr (st louis mo)   |   | |
Post# 723433 , Reply# 2   12/27/2013 at 16:36 (3,771 days old) by appnut (TX)   |   | |
Post# 723440 , Reply# 3   12/27/2013 at 17:14 (3,771 days old) by Travis ()   |   | |
I'll dig out the machine when I can convince Chris to come over. It's pretty well buried in the garage. It must be a WO 65. |
Post# 723951 , Reply# 5   12/30/2013 at 19:01 (3,768 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have a WO-65-2 that I used for years and I converted it to the two [ real rinse ] model by changing the timer and the timer dial to ones from an older WO-65. As Tom mentioned it rinses MUCH better with TWO COMPLETE water changes and only uses 2 1/2 gallons more total water, I would never change it back to overflow rinsing.
The only advantage to the OF rinse is that it will help with soap scum removal if you use soap and have hard water, which is why Frigidaire switched to the OF rinsing, because with spin draining all the soap scum ends going to the center of the tub and is then plastered all over the clothing. |
Post# 723955 , Reply# 7   12/30/2013 at 19:20 (3,768 days old) by swestoyz (Cedar Falls, IA)   |   | |
Congrats Travis! Looking forward to seeing some photos once you have a chance.
Robert has posted the early Unimatic service manual on AE. It covers the WO-65.
Ben CLICK HERE TO GO TO swestoyz's LINK |
Post# 723960 , Reply# 8   12/30/2013 at 19:40 (3,767 days old) by Travis ()   |   | |
Ben, Thanks. I just got it. Now to figure it out! |
