Thread Number: 50252
Vintage 1956 Fridgidaire Electric range` - $100 (Brighton) |
Post# 724790   1/3/2014 at 17:51 (3,737 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Ad: "
First $100 cash takes it! I need it out of my kitchen. Vintage stove in good working condition. Currently in use. Built by General Motors in Dayton, Ohio. All original, no modifications. Model: RIS-39-57, Serial: 25C 50597. 30"W x 26"D. Everything works except the left front burner and timer/clock. Enamel in excellent condition. I don't have the time to restore it, but it would be easy. Need to sell, make an offer!" CLICK HERE TO GO TO ovrphil's LINK on Rochester Craigslist |
Post# 724794 , Reply# 1   1/3/2014 at 17:57 (3,737 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 724827 , Reply# 3   1/3/2014 at 19:07 (3,737 days old) by PhilR (Quebec Canada)   |   | |
In 1956, the Canadian models were almost like the US models (except for fuses). Even the porcelain in the ovens was still gray. Canadian ranges had the Speed Heat feature until sometime in 1959. Even my 1959 Custom Imperial still has the Speed Heat and Canadian newspaper ads also talked about the Speed Heat burner (but some 1959 Custom Imperial ranges don't have it and no 1960 ranges have the Speed Heat). The Heat Minder was standard on the same models as in the US lineup until 1961 when the 40" ranges (except Flairs) were discontinued and mid-1962 when the 30" ranges were redesigned (the Heat-Minder was still available on the Imperial and Custom Imperial free-standing ranges, Imperial cooktops and Custom Imperial Flairs ranges).
According to my documents, the Speed Heat and Heat Minder were deleted on the RIS-39-56 |
Post# 724831 , Reply# 4   1/3/2014 at 19:17 (3,736 days old) by PhilR (Quebec Canada)   |   | |
Post# 724841 , Reply# 5   1/3/2014 at 19:31 (3,736 days old) by Tomturbomatic (Beltsville, MD)   |   | |
So it's just a typo. I should have checked the original ad. |
Post# 724890 , Reply# 6   1/3/2014 at 22:14 (3,736 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 724892 , Reply# 7   1/3/2014 at 22:25 (3,736 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 724920 , Reply# 8   1/4/2014 at 02:08 (3,736 days old) by washdaddy (Baltimore)   |   | |
Mark- I don't know all the facts ....but maybe Ben needed a space heater for the big storm running across the country and got himself a little confused trying to keep himself warm. (Ducking and running) lol ;) |
Post# 724924 , Reply# 9   1/4/2014 at 03:25 (3,736 days old) by PhilR (Quebec Canada)   |   | |
Ben, that's a nice '57 Deluxe! Now this one has the Speed Heat and Heat Minder! Do you know if they still work? Somebody offered me a '57 Imperial but both front burners were converted to regular (I haven't looked to see if they were 3 wire 5 heat or infinite heat type but it was missing 3 knobs and 2 chains and needles for the burners).
Post# 724931 , Reply# 10   1/4/2014 at 04:57 (3,736 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 725033 , Reply# 11   1/4/2014 at 14:39 (3,736 days old) by swestoyz (Cedar Falls, IA)   |   | |
As to be expected, the Speed Heat burner was not working. The Heat Minder did warm up, but I didn't have time to actually test it's Minding abilities. I really want to restore this one and use it for a bit in the kitchen, as I've never had the privilege of using a GM range before. Anyone here happen to have any spare Speed Heat burners and switches?
Yes, I'm trying to stay warm, but that's what the GE double oven Americana is for in the kitchen. ;) Ben This post was last edited 01/04/2014 at 15:23 |
Post# 725123 , Reply# 12   1/4/2014 at 21:29 (3,735 days old) by PhilR (Quebec Canada)   |   | |
Ben, I had one spare Speed Heat burner but I used it recently to make my '59 range work again. Your range's Heat Minder system seems to be quite complicated compared to the system that was introduced in 1960 (and that was used to convert the 1959 Charcoal range you sold recently which had another complicated system). I did the same with my 1959 CI range.
If your range still has the Speed Heat switch and it has problems, don't throw it away! I replaced the switches on both my 1959 Custom Imperial and my 1968 (US-market) Compact 30 and I had to keep the metal cover, the shaft and the cam for both so the shafts would be the correct length, the original knobs would fit and the switch would work as indicated by the knob/pointer.
The pre-1960 Speed Heat switches started on HIGH like the 5 heat switches and like the early regular infinite switches that were used on some 1958-59 models for the rear burners. The regular infinite switches were redesigned in 1960 but the Speed Heat switches remained almost unchanged through the 1960s.
First test the 6" burner to see if it has conductivity and if it's a 118V (about 10 ohms) or a 236V (over 30 ohms). If the burner has conductivity and shows a resistance value around 10 ohms, you probably don't have to replace the burner itself... When you'll be ready to check that, let me know what you find! I wish I had more Speed Heat parts to help you but I used most of what I had to repair my 1959 range recently (got parts from a US-built cooktop sometime ago on eBay). Speed Heat burners have been available only a few years here 1955 to mid-1959 so it's hard to get parts for these in Canada).
If you need more information, don't hesitate to email me and I'll try to help! |
Post# 725139 , Reply# 13   1/4/2014 at 23:30 (3,735 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 725140 , Reply# 14   1/5/2014 at 00:50 (3,735 days old) by PhilR (Quebec Canada)   |   | |
Yes I was using a newer Speed Heat switch... There were a few minor changes over the years but I assume that the later ones were improved (I read that somewhere...). But the main difference between the older and newer ones is the cam and the shaft. There were also shorter shafts used in cooktops but the shape of the shaft changed depending on the type of knob and year.
Replacing the cam in a newer Speed Heat switch will make it operate like the older one (starting on "high" instead of starting on "sim" when you turn the knob clockwise)
I just checked a 236V 6" burner with the ohmmeter and it shows 42 ohms resistance. |
Post# 725229 , Reply# 15   1/5/2014 at 12:55 (3,735 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 725306 , Reply# 16   1/5/2014 at 16:32 (3,735 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 773255 , Reply# 17   7/26/2014 at 15:14 (3,533 days old) by cree ()   |   | |
I bought the above range that was for sale does anyone know where I can find a clock/timer to replace the one in it that doesn't work...Thank You..Robert CLICK HERE TO GO TO cree's LINK |
Post# 773279 , Reply# 18   7/26/2014 at 19:24 (3,533 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 773328 , Reply# 19   7/26/2014 at 23:46 (3,532 days old) by PhilR (Quebec Canada)   |   | |
Post# 773362 , Reply# 20   7/27/2014 at 06:52 (3,532 days old) by cree ()   |   | |
Thank you for the reply I bought the 1956 Imperial the front burner that didn't work was no problem as it was just a loose wire but the clock timer is a different story.!! |
Post# 773364 , Reply# 21   7/27/2014 at 07:06 (3,532 days old) by cree ()   |   | |
The only other problem that it had was the fact that the broiler doesn't work but that to is probably the switch other than that its a very well built and working stove.!!! |
Post# 773401 , Reply# 22   7/27/2014 at 11:46 (3,532 days old) by PhilR (Quebec Canada)   |   | |
The next time you have to access the back of your range, you should take a picture of your clock.
As for the broiler, you can make a few tests with a multimeter with the range disconnected. The first one would be to see if the broil element is working by testing the continuity between the two connectors with the ohmmeter. |
Post# 773567 , Reply# 23   7/28/2014 at 09:27 (3,531 days old) by cree ()   |   | |
The difficult part is trying to locate a part number on the c/t as any paper or sticker on the back of it is gone..Thank You...Robert |
Post# 773580 , Reply# 24   7/28/2014 at 12:45 (3,531 days old) by PhilR (Quebec Canada)   |   | |
If the timer has a Telechron H3 rotor like this (it could be a different color like copper), that's the first thing to look at. The last picture shows the rest of the motor with the rotor removed from it. With the motor removed and the rotor still in the motor, you can see if the gear on the rotor rotates or not when you reconnect the range. Just be careful when you do that not to short circuit or to touch any live wire. You can also remove the complete timer assembly and test it on a bench by applying 115 volts to the two wires that go to the clock motor. Just note where all the wires go or take pictures first (that's the reason why I took some pics of this 1958-59 timer).
Some models use different timer movements like Robertshaw Lux Time or Internal Register. I don't know what was used in 1956.
