Thread Number: 50638
kds 18 not advancing |
Post# 728630 , Reply# 1   1/18/2014 at 21:34 (3,749 days old) by bmr6969 (columbus ohio)   |   | |
There are a few on eBay right now |
Post# 728640 , Reply# 2   1/18/2014 at 22:03 (3,749 days old) by epixstar128 (toledo)   |   | |
Do you have a part number cant find any |
Post# 728680 , Reply# 4   1/19/2014 at 06:08 (3,749 days old) by bmr6969 (columbus ohio)   |   | |
if you decide to junk it let me know i would be intrested in it for parts |
Post# 728687 , Reply# 5   1/19/2014 at 07:24 (3,749 days old) by epixstar128 (toledo)   |   | |
Any hope of fixing the one i have in there now |
Post# 728688 , Reply# 6   1/19/2014 at 07:40 (3,749 days old) by epixstar128 (toledo)   |   | |
How is the drain pump know when to shut off or is it just a timed sequence |
Post# 728695 , Reply# 7   1/19/2014 at 08:10 (3,749 days old) by bmr6969 (columbus ohio)   |   | |
its all through the timer that model doesnt have a drain pump but rather a drain silenoid |
Post# 728748 , Reply# 8   1/19/2014 at 11:46 (3,749 days old) by epixstar128 (toledo)   |   | |
Thanks being whirlpool oem is this a direct replacment. Im gonna take the old one apart tonight |
Post# 728749 , Reply# 9   1/19/2014 at 11:58 (3,748 days old) by bmr6969 (columbus ohio)   |   | |
should be...... i replaced mine a couple years ago |
Post# 728750 , Reply# 10   1/19/2014 at 12:05 (3,748 days old) by epixstar128 (toledo)   |   | |
Thanks i may order it tonight if i have the funds |
Post# 728754 , Reply# 11   1/19/2014 at 12:21 (3,748 days old) by bmr6969 (columbus ohio)   |   | |
cool again dont trash the machine i will buy it off you for parts atleast i have 2 kds 18's |
Post# 728759 , Reply# 12   1/19/2014 at 12:51 (3,748 days old) by epixstar128 (toledo)   |   | |
Sorry im attached to my kds she will live again |
Post# 728764 , Reply# 13   1/19/2014 at 13:29 (3,748 days old) by bmr6969 (columbus ohio)   |   | |
good man!! |
Post# 728932 , Reply# 14   1/19/2014 at 22:42 (3,748 days old) by epixstar128 (toledo)   |   | |
So i watched the timer with the unit on. No motors were turning at all. Took the timer out test both motors and they both work. Any ideas on why no power is being sent to the timer motors. |
Post# 728979 , Reply# 15   1/20/2014 at 06:06 (3,748 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I would pull the machine out and check the connections.
Years ago when coldspot66 gave me my first KDS 18, I hooked it up and the motor would run, but no lights, timer advance or fill. Turns out there was one wire I think it was on the wash heating element that had fallen off during the transportation. Hooked back up and it was fine. So, just saying, make sure everything is connected and go from there. |
Post# 729001 , Reply# 16   1/20/2014 at 07:19 (3,748 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Eric, try testing for timer motor movement with the timer plugged into the DWs wiring harness, even if the motors run it is possible that the gear train within the timer is bad and you may still need a new timer.
If the timer motors will not run when they are connected to the machines harness then it could be any number of possibilities as Eddie suggested. It could still be an electrical connection within the timer, or a bad selector Sw, broken wires where the wiring flexes in the door hinge area. The easiest thing is trying a good substitute timer at this point. Good Luck John L. |
Post# 729002 , Reply# 17   1/20/2014 at 07:26 (3,748 days old) by epixstar128 (toledo)   |   | |
Fair enough I will buy a new one worst case I have A new one for the future. |
Post# 729152 , Reply# 18   1/20/2014 at 18:57 (3,747 days old) by epixstar128 (toledo)   |   | |
if anyone had a service manuel I could get from them it would help me out alot |
Post# 729156 , Reply# 19   1/20/2014 at 19:07 (3,747 days old) by beekeyknee (Columbia, MO)   |   | |
Post# 729312 , Reply# 20   1/21/2014 at 08:45 (3,747 days old) by epixstar128 (toledo)   |   | |
Thanks we'll worth 3 buck |
Post# 729556 , Reply# 21   1/22/2014 at 06:58 (3,746 days old) by epixstar128 (toledo)   |   | |
Well with a good diagram i found that the neutral that feeds the two motors and the time had come loose. So my old girl is washing away again Thanks everybody for your help |
Post# 729558 , Reply# 22   1/22/2014 at 07:13 (3,746 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 729576 , Reply# 23   1/22/2014 at 09:21 (3,746 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
