Thread Number: 50658
SQ solid tub what now? |
Post# 728761   1/19/2014 at 13:12 (3,743 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 728762 , Reply# 1   1/19/2014 at 13:14 (3,743 days old) by epixstar128 (toledo)   |   | |
Apply some heat to them first and penetrating. Lube at least over night |
Post# 728800 , Reply# 2   1/19/2014 at 16:22 (3,742 days old) by akronman (Akron/Cleveland Ohio)   |   | |
and chip away at the dried crud/scum and then resoak, so you know the PB Blaster gets down under the bolt head. Make sure to use a 6 sided socket, not 12, so all your force goes into turning the bolt, not into ruining your socket. Don't be afraid to use a rubber mallet, one hit or so to TIGHTEN, believe it or not, then lots of hits to loosen. Anything is better than shearing them off. You may get a few out and then need more advice and more old tricks to get the next few. PATIENCE.
As for the screws, same process of soaking and scraping away crud and resoaking, then get a vise grip on your biggest screwdriver for extra torque. Heat one screw. Also apply pressure downward on the screwdriver so your force goes into turning the screw, not jumping out of the grooves. PATIENE. |
Post# 728887 , Reply# 3   1/19/2014 at 19:40 (3,742 days old) by washman (o)   |   | |
I look forward to seeing this grand old piece of history in operation once again. |
Post# 728908 , Reply# 4   1/19/2014 at 20:45 (3,742 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Don't remove the 8 screws that hold the tub to the agitator post, just remove the four bolts around the mid-section. Apply heat and they should come right out. Once those are out, you can rock the tub and get it loose from the spin hub.
The new agitator post kits came with new screws as it was rare to get the old stainless screws out of the pot metal base of the post. |
Post# 729025 , Reply# 5   1/20/2014 at 09:26 (3,742 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 729088 , Reply# 7   1/20/2014 at 15:13 (3,741 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 731575 , Reply# 8   1/29/2014 at 15:32 (3,732 days old) by everythingold (Grand Rapids, Michigan)   |   | |
