Thread Number: 50679
Drain Hose Plumbing |
Post# 729023 , Reply# 1   1/20/2014 at 09:23 (3,720 days old) by liberatordeluxe (UK)   |   | |
Pictures of drain hose continued, this should of been the first to upload. |
Post# 729024 , Reply# 2   1/20/2014 at 09:25 (3,720 days old) by liberatordeluxe (UK)   |   | |
And finally the standpipe. |
Post# 729043 , Reply# 3   1/20/2014 at 11:06 (3,720 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Although it would be better if it did not have that bow in the middle which might in time lead to the hose pulling out of the pipe with the weight of the water.
What is not so good is that multi socket hanging unsupported, with what I presume is a washing machine and dishwasher both connected to it. I hope you are not attempting to run both together at once. Seriously, it is not good practice to connect a washing machine and or dishwasher to one of these at all, given the current draw for extended periods. If you have only a single socket there are plenty of conversion kits available (Wickes/B&Q) which easily allow you convert a single to a double without having to chase out the wall to accept a larger mounting box. One of these would be a LOT safer. And whats with the hot water hose kinked back on itself? |
Post# 729323 , Reply# 5   1/21/2014 at 09:33 (3,719 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
No need for a new tap or fitting, if you are not using it just close it by using a pair of pliers or grips to move the post, it only has to go through 90 degrees after all. Just make sure that when it feels like it is off, it actually is off, I have found on a number of occasions that these valves do not entirely shut the water off.
As the hose appears to be long enough I would just supply a bit more support for it, a couple of large hooks or even a couple of cable ties closed loosely (so you can thread the hose through) and secured to the underside of the work top should be fine. Don't forget that if you bring the waste pipe over anything sitting in front of it will stick out further than it might otherwise do. I think (its a while since I looked at it) the hose from my Miele washer exits from the top of the machine Al |
Post# 729623 , Reply# 6   1/22/2014 at 13:55 (3,718 days old) by liberatordeluxe (UK)   |   | |
Thanks for those suggestions Al. Most helpful. Ben |
