Thread Number: 50725
Philips AWB135 washing machine |
Post# 729684   1/22/2014 at 17:52 (3,744 days old) by statomatic (France)   |   | |
Hi there, here are some pics of my Philips T635 / AWB135 washing machine.
I get this for free because the spin didn't started due to worn carbon brushes. It's the entry level model so the second rinse has a heating sequence because it is the start of the 30°C delicate program (n°5), the next three rinses did a gentle action even when you did a washing with normal action. (it's designed like this for have just one cycle so the timer is more simple and less expensive). Electrical circuits are a bit uncommon, the heating element is connected in series with the motor and its electronic control circuit, so the motor is shorted when the heating sequence (the high end models have an electronic temperature control too). The spin speed is adjustable from 200 to 550 rpm (the T800 series reaches 750 rpm), this speed is controlled by a very simple electronic module (nor ic's, nor microprocessor neither tachometer, just a pair of thyristors and diodes and some resistors and capacitors). The motor is a DC type with permanent magnet, it is made in Italy. Of course this machine did a "spin drain" (spinning starts at 200 rpm and increases until the tub empties). |
Post# 729685 , Reply# 1   1/22/2014 at 17:54 (3,744 days old) by statomatic (France)   |   | |
Post# 729687 , Reply# 2   1/22/2014 at 18:00 (3,744 days old) by statomatic (France)   |   | |
Post# 729691 , Reply# 3   1/22/2014 at 18:12 (3,744 days old) by statomatic (France)   |   | |
Post# 729891 , Reply# 5   1/23/2014 at 13:54 (3,743 days old) by matchboxpaul (U.K)   |   | |
This is the UK's AWB144 in white, from 1985... |
Post# 729892 , Reply# 6   1/23/2014 at 13:55 (3,743 days old) by matchboxpaul (U.K)   |   | |
and the UK's AWB147 Slimstar Mark III, again from 1985... |
Post# 729893 , Reply# 7   1/23/2014 at 13:56 (3,743 days old) by matchboxpaul (U.K)   |   | |
the earlier AWB117 Slimstar Mark II, from 1982 - now in the safe hands of Richard in Bristol ... |
Post# 729894 , Reply# 8   1/23/2014 at 13:57 (3,743 days old) by matchboxpaul (U.K)   |   | |
the bronze version HN3156 from 1978 ... |
Post# 729895 , Reply# 9   1/23/2014 at 14:00 (3,743 days old) by matchboxpaul (U.K)   |   | |
and the earlier blue version HN3156, first available in the UK in 1973... |
Post# 729896 , Reply# 10   1/23/2014 at 14:01 (3,743 days old) by matchboxpaul (U.K)   |   | |
Anyone any more photos of Slimstar variations? Paul |
Post# 729930 , Reply# 11   1/23/2014 at 16:41 (3,743 days old) by sesteve (London, UK)   |   | |
Hi Statomatic
Great machine too and love the access with the casing off. That plastic chassis is something else. For all my Slimstar wobbles a bit on spin it is quite stable overall so perhaps that's why they moved to the plastic. I guess the spin speed on yours is quite a bit slower too. I love all the variants there too Paul. Great pics S |
Post# 729933 , Reply# 12   1/23/2014 at 16:47 (3,743 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
As mentioned before, but should be said in this thread too, there is a big difference between the 45cm and the 40cm wide models. The 45cm ones were made in the UK, the 40cm ones in France. The design is quite different too, albeit both had the spindrain sequence. But spindrains were more common back then.
Post# 729953 , Reply# 13   1/23/2014 at 19:28 (3,743 days old) by statomatic (France)   |   | |
Post# 729956 , Reply# 14   1/23/2014 at 19:36 (3,743 days old) by statomatic (France)   |   | |
Post# 729957 , Reply# 15   1/23/2014 at 19:37 (3,743 days old) by statomatic (France)   |   | |
Post# 729958 , Reply# 16   1/23/2014 at 19:39 (3,743 days old) by statomatic (France)   |   | |
