Thread Number: 5086
Thomson TX898 - No paddles in drum? |
Post# 111143   2/21/2006 at 12:14 (6,637 days old) by the7 ()   |   | |
Thomson TX is my son's new Euro-size FL washer/dryer in HK. It can wash 6 kg and dry 3kg. See 1st photo Apparently there is no paddle in the drum. See the next 2 photos. |
Post# 111144 , Reply# 1   2/21/2006 at 12:15 (6,637 days old) by the7 ()   |   | |
Is this the only paddle? |
Post# 111146 , Reply# 2   2/21/2006 at 12:18 (6,637 days old) by the7 ()   |   | |
Are these the Hot air inlet and return when used as dryer? |
Post# 111147 , Reply# 3   2/21/2006 at 12:20 (6,637 days old) by toggleswitch (New York City, NY)   |   | |
Post# 111151 , Reply# 4   2/21/2006 at 12:38 (6,637 days old) by the7 ()   |   | |
The left hand side inlet is for water-jets (not Hot air). See Photo. |
Post# 111185 , Reply# 6   2/21/2006 at 14:41 (6,637 days old) by frigilux (The Minnesota Prairie)   |   | |
Interesting! Thanks for posting the pics. How on earth do the clothes get picked up and dropped if there are no paddles? Hour and 40 min. for wash, hour and 30 min. to dry. That's quite a time commitment for a single load of laundry. I wonder if the top-loading horizontal axis machine will ever catch on in the US? There is some talk about Whirlpool having a patent for just such a washer... |
Post# 111186 , Reply# 7   2/21/2006 at 14:42 (6,637 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 111209 , Reply# 8   2/21/2006 at 16:07 (6,637 days old) by the7 ()   |   | |
I will email my son to look again to see if there are any other paddle-like objects besides the only one at the bottom. |
Post# 111309 , Reply# 9   2/22/2006 at 04:50 (6,636 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 111529 , Reply# 15   2/23/2006 at 07:11 (6,635 days old) by toggleswitch (New York City, NY)   |   | |
Post# 111554 , Reply# 16   2/23/2006 at 10:00 (6,635 days old) by designgeek ()   |   | |
Very interesting; I definitely want to get back to this topic but will have to wait until tonight.... |
Post# 111616 , Reply# 18   2/23/2006 at 17:51 (6,635 days old) by the7 ()   |   | |
Thomson TX898 in HK is supplied at 220V 50Hz 15A circuit. So it could have a high power heater (say 2000-2500 watts) for heating washer water and for drying. It also has only one COLD inlet. |
Post# 111727 , Reply# 19   2/24/2006 at 04:49 (6,634 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Yes, I like European H-axis toploaders, it's definitely a very effective design. I'm fascinated by that. On the other hand it's also the most boring design since you can't see what is happening. No wash day drama here!! The Thomson can draw max. 2200 Watts, so the heating element is probably 2000 Watts. It means it can be connected to a 10Amps circuit overhere. Monkeyward, I assume that you meant to say that the Staber uses a lot less water than regular TOPLOADERS on the market? The Staber isn't a very energy and water efficient machine, most new American frontloaders use less IIRC. The hexagonal drums create a lot of space between the drums, which increases the amount of water used. |
Post# 111859 , Reply# 20   2/24/2006 at 21:01 (6,634 days old) by the7 ()   |   | |
My son said: "There are no other objects other than the removable (not likely, as you need a "star-shaped" screwdriver") paddle at the bottom of the drum." So TX898 has only one small paddle at the bottm. |
Post# 111934 , Reply# 23   2/25/2006 at 10:39 (6,633 days old) by toggleswitch (New York City, NY)   |   | |
Post# 111944 , Reply# 24   2/25/2006 at 11:29 (6,633 days old) by the7 ()   |   | |
My son replied: "Yup. That is possible. Can combine with 1-19 hours delay, eco care, sleekare setting too." So it confirms that TX898 could be programmed to wash and dry in one go. |
