Thread Number: 50910
Another kenmore 300 wringer question |
Post# 732028 , Reply# 1   1/31/2014 at 12:42 (3,730 days old) by mickeyd (Hamburg NY)   |   | |
Damien, can you get any pix up? Not familiar with the numerical sequences, but in the general, the lower end models of most brands did not have an OFF/ON switch -- you just pulled the plug -- as you say, while the higher end models had an OFF position on the timer dial, and a HOLD position to keep the motor running without engaging the timer. A few, like the Easy wringer, did sport an actual OFF/ON switch, separate from the timer. I doubt that your machine has such a switch. Will locate my KM Wringer Book later, and see what's there.
Would love to see your 300 machine, inside and out. |
Post# 732504 , Reply# 2   2/2/2014 at 16:08 (3,728 days old) by 2011hoovermatic (owosso michigan)   |   | |
@ mickyd I Would love some specification by photos inside and out but here's a few to start. |
Post# 732507 , Reply# 3   2/2/2014 at 16:10 (3,728 days old) by 2011hoovermatic (owosso michigan)   |   | |
2 |
Post# 732509 , Reply# 4   2/2/2014 at 16:14 (3,728 days old) by 2011hoovermatic (owosso michigan)   |   | |
3 that wash (may be rinse water) shows how well these work. more pics are on the way stay tuned. |
Post# 733520 , Reply# 5   2/7/2014 at 13:16 (3,723 days old) by laundryboy (Orlando Florida & Moravia NY. )   |   | |
Post# 735914 , Reply# 6   2/17/2014 at 18:41 (3,713 days old) by 2011hoovermatic (owosso michigan)   |   | |
bump |
Post# 737904 , Reply# 8   2/26/2014 at 18:13 (3,704 days old) by mickeyd (Hamburg NY)   |   | |
Some makes with timers also have speed switches; that way if you want a gentle touch on a soiled load, you can wash for the max time of 25 minutes on gentle speed. NOTE: The timer turns clockwise all the way to just before HOLD, yielding 25 minutes, and counterclockwise for the HOLD setting.
The "HOLD" setting allows you to keep the motor running in whatever mode you're using wash, wring, drain, or all of the above. Where the term comes form is still a mystery: On a dishwasher, HOLD, means still and off, as in Rinse and Hold. On the conventional washers, HOLD means ON and running. Interesting. One day. I hope to find the reason for this earlier usage. I've seen your straight vane agi here recently in a few other machines, but not a stand alone for sale. Keep looking. Things turn up around here like turnips at harvest time. |
Post# 741545 , Reply# 9   3/13/2014 at 09:20 (3,689 days old) by 2011hoovermatic (owosso michigan)   |   | |
bump |
Post# 746323 , Reply# 10   3/30/2014 at 16:57 (3,672 days old) by 2011hoovermatic (owosso michigan)   |   | |
bump |
Post# 748669 , Reply# 12   4/8/2014 at 10:41 (3,663 days old) by 2011hoovermatic (owosso michigan)   |   | |
Nothing is wrong with the agitator itself I just wondered so I can like maybe do only a couple strokes with the agitator on delicates. with mine I'll just have to do that manually. Hopefully I'll do some wringing and taking some photos soon. so stay tuned. |
Post# 752012 , Reply# 13   4/22/2014 at 20:25 (3,649 days old) by 2011hoovermatic (owosso michigan)   |   | |
bump |
Post# 756119 , Reply# 14   5/10/2014 at 15:51 (3,631 days old) by 2011hoovermatic (owosso michigan)   |   | |
bump |
Post# 760663 , Reply# 15   5/31/2014 at 19:18 (3,610 days old) by 2011hoovermatic (owosso michigan)   |   | |
bump |
