Thread Number: 50967
Work Begins on the KD-10 |
Post# 732772   2/4/2014 at 07:29 (3,704 days old) by dosxxpapa (Oregon)   |   | |
I have started to dissemble the KD-10. I was able to remove the impeller with two screwdrivers moving it slowly off the shaft. All seals are brittle and are just crumbling apart.
I will need all new seals, so if anyone has any idea on where to get them or what would work, please let me know. I hope to be able to work on it more sometime this week. Next, working on taking out the motor. Steve, thanks for the great instructions about the two screwdrivers to remove the impeller, worked great and I did not need any PB Blaster to do the job. Will keep everyone informed of the progress. Joe |
Post# 732831 , Reply# 1   2/4/2014 at 14:10 (3,704 days old) by dosxxpapa (Oregon)   |   | |
Post# 732834 , Reply# 2   2/4/2014 at 14:24 (3,704 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 732838 , Reply# 3   2/4/2014 at 14:43 (3,704 days old) by dosxxpapa (Oregon)   |   | |
Here is the Part Number and the link to where you can get one if you need it.
EPM Home of the Seal Man. Mechanical Seals For Hobart Mfg. P/N R 23682 Thanks Joe CLICK HERE TO GO TO dosxxpapa's LINK |
Post# 733340 , Reply# 5   2/6/2014 at 11:13 (3,702 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 733342 , Reply# 6   2/6/2014 at 11:27 (3,702 days old) by dosxxpapa (Oregon)   |   | |
Post# 733348 , Reply# 7   2/6/2014 at 12:13 (3,702 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 733519 , Reply# 8   2/7/2014 at 13:15 (3,701 days old) by dosxxpapa (Oregon)   |   | |
Post# 733529 , Reply# 9   2/7/2014 at 14:17 (3,701 days old) by dosxxpapa (Oregon)   |   | |
Post# 734072 , Reply# 10   2/9/2014 at 18:36 (3,699 days old) by dosxxpapa (Oregon)   |   | |
Post# 734092 , Reply# 11   2/9/2014 at 19:36 (3,699 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 734204 , Reply# 12   2/10/2014 at 07:57 (3,698 days old) by dosxxpapa (Oregon)   |   | |
Post# 734205 , Reply# 13   2/10/2014 at 08:15 (3,698 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 734214 , Reply# 14   2/10/2014 at 09:23 (3,698 days old) by stevet (West Melbourne, FL)   |   | |
With the screwdriver tip! We still use that same method when it comes to removing impellers on the larger machines. |
Post# 734222 , Reply# 15   2/10/2014 at 10:53 (3,698 days old) by dosxxpapa (Oregon)   |   | |
Post# 734231 , Reply# 16   2/10/2014 at 11:46 (3,698 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 734240 , Reply# 17   2/10/2014 at 13:32 (3,698 days old) by chachp (North Little Rock, AR)   |   | |
Post# 734241 , Reply# 18   2/10/2014 at 13:35 (3,698 days old) by Unimatic1140 (Minneapolis)   |   | |
Great work Joe, it's coming along nicely!!!
Just a heads up, those rubber gaskets you cut, might work but if there still is some leaks you should cut cork gaskets. I have found that on brand new parts rubber works just fine, but on old parts where detergent has corroded a bit of the sealing surfaces cork seals much better. You can get cork on a roll at any auto parts store. |
Post# 734251 , Reply# 19   2/10/2014 at 14:32 (3,698 days old) by dosxxpapa (Oregon)   |   | |
Hey Robert,
Thanks, I am always open to suggestions. This is my first vintage dishwasher repair. I really don't want to do this twice. I would hate to use rubber gaskets and put it all back together and have leaks. So since I am the novice, I took your advice and went down to get a roll of cork material at the auto parts store. So I am going to make gaskets out of cork now. New seals will be here on Wednesday, no idea about the motor. It just depends on what needs to be done. No idea on cost or time it will take to have motor done. I told them it does not matter, I want the Old Gal up and running again. When I find out cost and time I will let everyone know. Thanks Again!!! Joe |
Post# 735204 , Reply# 20   2/14/2014 at 10:26 (3,694 days old) by dosxxpapa (Oregon)   |   | |
Post# 736627 , Reply# 21   2/20/2014 at 19:05 (3,688 days old) by dosxxpapa (Oregon)   |   | |
Post# 738159 , Reply# 22   2/27/2014 at 22:28 (3,681 days old) by dosxxpapa (Oregon)   |   | |
