Thread Number: 51057
Maytag Reverse Rack Question |
Post# 733847 , Reply# 1   2/8/2014 at 20:50 (3,700 days old) by cam2s (Nebraska)   |   | |
And here it is with the added water. The water is touching the bottom of the heat guards on the wash arm, and there was still some surging in the pump. |
Post# 733902 , Reply# 2   2/9/2014 at 04:18 (3,700 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 733973 , Reply# 4   2/9/2014 at 11:36 (3,699 days old) by Yogitunes (New Jersey)   |   | |
Post# 733992 , Reply# 5   2/9/2014 at 13:43 (3,699 days old) by appnut (TX)   |   | |
Post# 733994 , Reply# 7   2/9/2014 at 13:50 (3,699 days old) by cam2s (Nebraska)   |   | |
Micro Mesh filter |
Post# 734018 , Reply# 8   2/9/2014 at 15:55 (3,699 days old) by nmassman44 (Brooksville Florida)   |   | |
If you look at the pic in reply #7 you will see under the back flush arm that the bearing/seal ring is split. I am willing to bet that when the wash pump is going that water is surging out that seal and not pressuring the arms and tower like it should be. Just a thought .also look at the lower arm sides, they tend to split.
