Thread Number: 51147
Deep well stove element. How was it used? |
Post# 735111 , Reply# 1   2/14/2014 at 00:31 (3,695 days old) by rp2813 (Sannazay)   |   | |
The stove originally came with a pot specifically designed for deep well use.
Someone here may be able to post a picture of one, in case you're interested in hunting one down.
A picture of your stove to confirm its age would help nail down the correct deep well pot for it.
The average pot won't work in the deep well, since they have handles attached to the sides. All deep well pots have a lip around the top edge with handles incorporated so the pot can be fully sunken into the well and make contact with the element.
You're lucky to have the option to use the deep well element as a regular surface burner. My mom's '49 Westinghouse had a stationary deep well element. No versatility at all.
Post# 735126 , Reply# 4   2/14/2014 at 02:16 (3,695 days old) by norgeway (mocksville n c )   |   | |
Has a 8 inch unit!! |
Post# 735127 , Reply# 5   2/14/2014 at 02:17 (3,695 days old) by norgeway (mocksville n c )   |   | |
You lower it. |
Post# 735128 , Reply# 6   2/14/2014 at 02:18 (3,695 days old) by norgeway (mocksville n c )   |   | |
Position.. |
Post# 735129 , Reply# 7   2/14/2014 at 02:20 (3,695 days old) by norgeway (mocksville n c )   |   | |
The pot in place, I also have a Presto deep well pressure cooker, it came with a Kelvinator, but it fits the Norge fine. |
Post# 735154 , Reply# 9   2/14/2014 at 06:33 (3,694 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 735155 , Reply# 10   2/14/2014 at 06:46 (3,694 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 735158 , Reply# 11   2/14/2014 at 07:11 (3,694 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Deep-well cookers weren't an unalloyed joy.
First, the burners under them were usually the kind you have - open-coil nichrome elements that were of limited use when raised, and not exactly easy to clean, either. Second, the cooker caught cooking grease from the other burners, meaning that spatters ended up on the lid and handles of the deep-well pot. This was a real tooth-grinder after a while; I remember it well from the 1948 Frigidaire we had for so many years when I was growing up. Cleaning the cooktop after preparing a meal always involved some work involving the deep-well cooker or its burner, whether you used it or not. |
Post# 735167 , Reply# 12   2/14/2014 at 08:27 (3,694 days old) by countryguy (Astorville, ON, Canada)   |   | |
The stove we had in our house when I was growing up had the deep well on the left rear. It was a large burner and it worked just as Hans showed above. I'm not sure of the make of the stove. It was a 40" model with the 4 burners on the left. Below it was a pull out warming drawer and below that a pots/pans drawer. My mom used the warming drawer to store pots/pans - I never once saw it used as a warming drawer. The right side was just a flat surface with the oven below that and another pots/pans drawer below the oven. The oven door had a glass window. With all the pics of vintage stoves on this site, I've yet to come across one that was the same as what we had. I'm thinking that it was a Westinghouse but for some reason Marquette also sounds familiar. It had push buttons for the 4 surface units, clock, a round timer knob and a round knob for the oven temeperature. On the circumference of the oven switch there was another dial with 3 positions to select bake, broil or preheat.
Gary |
Post# 735176 , Reply# 13   2/14/2014 at 08:53 (3,694 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I've had a couple of deep-well cookers on ranges but have never utilized them fully. Tom kindly sent me the popcorn stirring arm for my Frigidaire range and I did use that several times with wonderful results. The high heat and heavy pan, somewhat insulated by the well in the range made for fast popping and never scorched.
That's a great finger-loop on your Norge element, Hans, it would make raising and lowering easier. |
Post# 735181 , Reply# 14   2/14/2014 at 08:58 (3,694 days old) by Kenmore71 (Minneapolis, MN)   |   | |
The early Frigidaires even had what they called the "Thriftomatic" control for the deep well cooker. This control had the the "High" setting on an adjustable 30 minute timer, which, when it got to end of whatever time you set on it, turned the heat down to "low". This allowed you to get everything up to cooking temperature and then it automatically turned down the heat.
Also, by the 1950s All of the Frigidaire deep well elements were 8", although they were usually of a lower wattage than the front unit (1600 watts if memory serves me correctly). |
Post# 735197 , Reply# 16   2/14/2014 at 09:15 (3,694 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Jeff noted years ago that the way some people cook, all surface units should have a switch that only allowed them to use high heat for an automatically timed period. |
Post# 735198 , Reply# 17   2/14/2014 at 09:19 (3,694 days old) by rp2813 (Sannazay)   |   | |
The deep well element on the '49 Westinghouse was 8" in diameter but it was the open coil nichrome type and didn't put out the same level of BTUs as the "Corox" elements.
The Westy's deep well pot had a steamer plate that could be positioned at various levels. I think this was an across-the-board design with all manufacturers. The picture Hans posted in reply #7 shows the notches in the side of the pot that hold the steamer plate.
The lid on the Westy's pot was not heavily insulated. It was aluminum, just like the rest of the pot.
I've been passing by a deep well pot at Salvation Army lately. It has no lid or identifying marks, and has been knocking around the cookware aisle for weeks. |
Post# 735215 , Reply# 19   2/14/2014 at 11:40 (3,694 days old) by gredmondson (San Francisco, California 94117 USA)   |   | |
Post# 735219 , Reply# 20   2/14/2014 at 12:00 (3,694 days old) by PhilR (Quebec Canada)   |   | |
Mark is right about Frigidaire deep wells, on my '59 Custom Imperial (last year for deep wells in Frigidaire ranges) the 8" burner had the same wattage as the rear 6" burner. And even if the the late-1950s Frigidaire deep well burners were controlled by an infinite switch, they kept the 3 wire design from earlier 5 heat burners. By 1959, all other burners that were used with an infinite switch had already switched to a 2 wire design.
Greg, can you send a picture of the popcorn stirrer? I have never seen that! |
Post# 735266 , Reply# 22   2/14/2014 at 19:27 (3,694 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 735269 , Reply# 23   2/14/2014 at 19:34 (3,694 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
In case I haven't said so before, I really like your kitchen. I was in dozens like it when I was growing up - and haven't seen one like it in a long time.
Everything's terribly built-in and elegant now, but the character is gone. P.S.: The cabinets in the house I grew up in were also knotty pine, but stained much darker. The hardware was exactly the same as yours. |
Post# 735295 , Reply# 24   2/14/2014 at 21:30 (3,694 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 735301 , Reply# 25   2/14/2014 at 21:53 (3,694 days old) by norgeway (mocksville n c )   |   | |
Because I intend on having it on mine..real Linoleum, with chrome edging! LOVE the pine cabinets and the real refrigerator and stove, their just isnt any comparison once you use good stuff!! |
Post# 735366 , Reply# 26   2/15/2014 at 04:00 (3,693 days old) by PhilR (Quebec Canada)   |   | |
Post# 735367 , Reply# 27   2/15/2014 at 04:12 (3,693 days old) by norgeway (mocksville n c )   |   | |
You could still get one on a Hotpoint in 61, but after that I have no idea, I love mine, but its one of those deals you love or hate. |
Post# 735403 , Reply# 28   2/15/2014 at 10:21 (3,693 days old) by cornutt (Huntsville, AL USA)   |   | |
Would love to see more pics of it. |
Post# 735427 , Reply# 29   2/15/2014 at 12:25 (3,693 days old) by rp2813 (Sannazay)   |   | |
Post# 735479 , Reply# 31   2/15/2014 at 16:54 (3,693 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
There aren't any GE ones on eBay at the moment, but that's where I would focus.
A bit of research dug up the fact that Mirro made a lot of the units for various manufacturers. Anyway, I'd search eBay for "deep well cooker" and do a "saved search" on it, so that you'll be notified as they come up on the site. Then I'd wait patiently for just the right unit at just the right price. It'll happen! |
Post# 735537 , Reply# 33   2/15/2014 at 20:06 (3,693 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 785792 , Reply# 35   9/26/2014 at 11:10 (3,470 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 785794 , Reply# 36   9/26/2014 at 11:29 (3,470 days old) by mrsclark ()   |   | |
It is white. |
Post# 786471 , Reply# 38   9/30/2014 at 11:10 (3,466 days old) by Tomturbomatic (Beltsville, MD)   |   | |
OR, you can buy the one for sale on eBay now and if you don't like it, you can wait and watch. |
Post# 786563 , Reply# 40   9/30/2014 at 18:57 (3,466 days old) by FEster (Lafayette La USA)   |   | |
Swap the burners in and out as needed. The best of both worlds. |
Post# 786571 , Reply# 41   9/30/2014 at 19:22 (3,466 days old) by mikael3 (Atlanta)   |   | |
No re-wiring necessary? |
Post# 991954 , Reply# 43   4/24/2018 at 09:42 (2,164 days old) by ken (NYS)   |   | |
Look on ebay. Search deep well pot or deep well cooker. Make sure you verify diameter and height. From what I've read here Mirro brand pots were supplied with Frigidaire and Norge ranges. There may have been others that also used Mirro. GE used Ekco brand. GE deep pots were smaller in diameter because the rear burner used with them was the smaller 6".
Here's one that may work for you. CLICK HERE TO GO TO ken's LINK on eBay |
Post# 992895 , Reply# 45   5/2/2018 at 16:34 (2,156 days old) by ken (NYS)   |   | |
But the tripod/burner support should be permanently attached to the element on that burner. When you drop the element down to use the deep well pot the support goes down with it. You don't want the element sitting directly on the porcelain surface of the liner.
I know it to be that way on a 56 Frigidaire as I have one. Don't know if it was different on earlier models. This post was last edited 05/02/2018 at 19:37 |
Post# 1024313 , Reply# 46   2/11/2019 at 15:20 (1,871 days old) by Geneva (Oklahoma City, OK)   |   | |
Son has just set a closing date for a home with a Frigidaire RO-60 range. Made in the USA!! I LOVE it! However, it is missing some parts. I found this site and am so excited. I put a watch out for a deep well pot and today, I see this on eBay. Would this fit it? They give dimensions, but he hasn't closed on the house yet, so I can't measure the opening. Hope I can get him one to fit!
CLICK HERE TO GO TO Geneva's LINK on eBay |
Post# 1024316 , Reply# 47   2/11/2019 at 16:41 (1,871 days old) by luxflairguy (Wilmington NC)   |   | |
YES! |
Post# 1024320 , Reply# 48   2/11/2019 at 17:14 (1,871 days old) by Geneva (Oklahoma City, OK)   |   | |
I have purchased the deep well pot on eBay! Thank you so much for helping me. No idea if I paid too much or got a great deal, but I REALLY wanted to have one. I'm happy! I fell in love with that RO-60. The 24 year old that is living with it now says the oven runs hot, but I'll bet she hasn't read about them. I got all three manuals from Automatic Ephemera and have read them. Hoping that turning to broil and then back to the temp wanted will help. I didn't see the divider for the upper and lower oven and am just hoping it is sitting on the bottom oven. The panel that folds down over the lower oven was in the bottom pan drawer, so hoping the rest is there! The range does so much! Am very excited! While he moves into the house, I'll be playing with the range. Thank you again!!
Post# 1024330 , Reply# 49   2/11/2019 at 19:02 (1,871 days old) by norgeway (mocksville n c )   |   | |
Ovens are easy to adjust. |
Post# 1024366 , Reply# 51   2/12/2019 at 08:20 (1,870 days old) by Geneva (Oklahoma City, OK)   |   | |
This RO-60 is being used currently, but only partially... When he closes on the house, should I have someone check out the wiring before I start trying everything out?
Post# 1024433 , Reply# 52   2/13/2019 at 02:07 (1,870 days old) by norgeway (mocksville n c )   |   | |
Do not get a electrician or young appliance tech , all they will do is tell you its old and unsafe, get someone like a older tech or better yet someone who specializes in old appliances, |
Post# 1093446 , Reply# 54   10/16/2020 at 18:13 (1,258 days old) by Zackolon (Lewes)   |   | |
Is this the oven your talking about ???
Post# 1093538 , Reply# 56   10/17/2020 at 18:36 (1,257 days old) by SudsMaster (SF Bay Area, California)   |   | |
In one of the rentals I lived, the push button GE electric range had one of those deep well cookers. I never used it. Cause the landlady said it was broken. I suppose if I had investigated I could have figured out the problem and fixed it, but it was never a big deal to me - I rarely use all four burners anyway. I just used it (it has a flat cover) to set pots to cool down.
Post# 1093539 , Reply# 57   10/17/2020 at 18:45 (1,257 days old) by MattL (Flushing, MI)   |   | |
Until we switched stoves the deep well was used quite a bit. I think it's handy. |
Post# 1094133 , Reply# 59   10/23/2020 at 06:00 (1,251 days old) by washerboy (Little Rock Arkansas)   |   | |
My grandmother and all my aunts had them. But every time I'd peek under the lid it was always the same thing; either green beans or turnip greens....seriously!!!..lol |
Post# 1095338 , Reply# 61   10/31/2020 at 21:10 (1,243 days old) by Steve340 (Puyallup)   |   | |
I bought this thinking it would fit my Hotpoint but the angle of my control panel is different than a GE.
Post# 1095350 , Reply# 62   10/31/2020 at 23:17 (1,243 days old) by RP2813 (Sannazay)   |   | |
I'll bet somebody here has a GE stove that deep fryer element would fit.
The deep well unit on my mom's '49 Westinghouse had the open coil/clay block heating unit, which she considered basically useless for anything but slow cookery. I think the most common things it was used for were soups and sauces, both of which were started in the deep well pot on top of a surface unit, then dropped into the deep well to simmer slowly over a period of hours. For pasta sauce, this freed up the large burner for boiling the water once the sauce was ready. Even though it could be used as a steamer quite effectively, never once did I witness that. |
Post# 1102095 , Reply# 63   12/26/2020 at 21:50 (1,187 days old) by MichMom (Midwest (USA))   |   | |
@Steve340 Yes, I've have a 1958 GE with the Deep Well Fryer socket. I would be interested in purchasing it from you.
Post# 1107392 , Reply# 64   2/9/2021 at 18:17 (1,142 days old) by MichMom (Midwest (USA))   |   | |
Thanks to Steve340!! The deep well fryer fits like a glove! So glad to have it. |
Post# 1107396 , Reply# 65   2/9/2021 at 18:45 (1,142 days old) by MattL (Flushing, MI)   |   | |
Wow, neat. I've long been on the look out for the deepwell pressure cooker insert for my Frigidaire range, they are very rare. |
