Thread Number: 51183
Miele 1918 Washer Noise during spin cycle |
Post# 735578 , Reply# 1   2/16/2014 at 00:35 (3,720 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Lavamats there is no way to get between the tubs of a Miele to fetch an errant item. The other models mentioned allow for the removal of one or more paddles so you can gain access to the area between inner and outer tub.
If the piece is small enough it may eventually work it's way down to the sump where the "detergent ball) that blocks the drain hose from tub while machine is filled with water may or may not keep it from reaching the filter. If by some means the thing does reach the filter then it should be an easy matter to get it out. Other than that only thing one can think of that the tub assembly will have to come out. That is the only way one believes the tubs can be separated. It is quite a lot of work IMHO. Pity you simply didn't open the front of the machine at the time and disconnect the hose leading from the dispenser to tubs. That would have allowed you to fetch out the bit before it got down between the tub. |
Post# 735603 , Reply# 3   2/16/2014 at 07:01 (3,719 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
... Take a look at page 36! CLICK HERE TO GO TO henene4's LINK |
