Thread Number: 51191
oil leaks |
Post# 735624   2/16/2014 at 10:48 (3,720 days old) by christfr (st louis mo)   |   | |
hey all has anyone ever had one of these apart to try and fix oil leaks? I know its just nature of the beast to leak oil but I wonder if trying to find seals would be worth the time and effort or not.. the machine is going to be painted a darker brown on the bottom half so that should help hide any leaks in the future, and im kinda not sure how low the oil level really is or if I should just put some in..
Post# 735641 , Reply# 1   2/16/2014 at 12:05 (3,720 days old) by bradross (New Westminster, BC., Canada)   |   | |
Hi Chris,
Jim from Ohio (wringer) was kind enough to send me pages from the parts manual. The page I've attached shows the cork gasket. In your machine, it may have deterioriated - I assume mine has to some degree as well. My machine has a few spots where oil VERY slowly seeps out, but nothing major, so I just periodically wipe it off. I guess you have to guage how severe your leak is. As I mentioned in the e-mail, you can always squirt a little heavy-weight oil or grease into the port - say, a 1/2 cup just to be sure it's not dry. Turn the vent cap while the machine is running to see if oil gurgles out - if so, it's full enough! |
Post# 735684 , Reply# 2   2/16/2014 at 17:11 (3,720 days old) by christfr (st louis mo)   |   | |
