Thread Number: 51193
1952 or '53 Westinghouse Twins |
Post# 735676 , Reply# 1   2/16/2014 at 17:00 (3,715 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
is okay then you are 90% home with one of these machines and if the leak isn't from there then the next culprits are the pump and the tub seal. On a machine this early you may have the cork gasket and if so the machine needs to be run regular to keep that cork plump. If the machine is used infrequently or hardly at all then the cork will dry out and she will leak on the next loads. The remedy for that is to run her regular and usually the cork plumps and you're good to go.
You know the front bottom panel pops right off so you can observe the machine running????
Post# 735718 , Reply# 3   2/16/2014 at 20:00 (3,715 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 735904 , Reply# 4   2/17/2014 at 17:23 (3,714 days old) by turquoisedude (.)   |   | |
Post# 736953 , Reply# 5   2/22/2014 at 07:45 (3,709 days old) by rex (north carolina)   |   | |
Thanks, TD, for your help and to everyone who answered. I'll officially add these to my long list of projects. By the way, does anyone know if Westinghouse made a gas dryer during this period? Rex |
Post# 736957 , Reply# 6   2/22/2014 at 08:24 (3,709 days old) by moparwash (Pittsburgh,PA )   |   | |
