Thread Number: 51248
40's 50's? GE dishwasher/sink in Ohio |
Post# 736303   2/19/2014 at 10:02 (3,717 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 736318 , Reply# 1   2/19/2014 at 10:58 (3,717 days old) by washdaddy (Baltimore)   |   | |
Ad says water won't come out but motor runs and impeller spins. Sounds like it has a pump problem or maybe a clogged up drain line. |
Post# 736319 , Reply# 2   2/19/2014 at 11:01 (3,717 days old) by mopar65 (Almont MI)   |   | |
Post# 736333 , Reply# 3   2/19/2014 at 11:47 (3,717 days old) by turquoisedude (.)   |   | |
Post# 736436 , Reply# 4   2/19/2014 at 19:34 (3,717 days old) by mopar65 (Almont MI)   |   | |
Post# 736918 , Reply# 5   2/22/2014 at 01:32 (3,714 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Anthony, I am guessing this is a model from 1953. GE started using the larger style air gap cover around that time. The first two digits of the serial number will tell you the manufactured year. Message me if you need help with this machine. I am betting the cause of the water not flowing is that the water valve is plugged up. These Dole water valves are fairly easily dissembled, cleaned with lime away or similar, and placed back on the dishwasher. Be sure to bench test it with a standard 110 cord attached to the solenoid wires, and connect water to the inlet side of the valve. Especially before you take the valve apart, you will know if the valve is plugged or not. Proceed accordingly. Mike |
Post# 736939 , Reply# 6   2/22/2014 at 06:45 (3,714 days old) by mopar65 (Almont MI)   |   | |
Post# 736977 , Reply# 7   2/22/2014 at 11:15 (3,714 days old) by appnut (TX)   |   | |
For history sake. Looks in fairly good shape inside. May be the photo angle, but the lift-out center section looks not perfectly centered, the right side of the top basket looks wider than the left side of the center lift-out section. Then again, the lift-out center section could be placed incorrectly anyway. And I always assumed this was perfectly, symmetrically situated.
Post# 737578 , Reply# 8   2/25/2014 at 12:08 (3,711 days old) by dishwashercrazy (West Peoria, IL)   |   | |
To Bob and anyone else who might be interested in the early GE Dishwashers: I am probably one of a very small group of us that is really interested in the engineering changes that GE made in Dishwasher technology between the 1930's and the early 1960's. This approximate 30 year window is of greatest interest to me as a collector, although I am still interested in earlier dishwashers such as Walker, and some dishwashers made after the 1960's. I am going to include a photo and several scanned images to illustrate some of those changes. I mainly wanted to comment specifically to Bob regarding the orientation of the GE dish racks, but I will try to address other changes too. This photo shows the racks from a 1949 GE top loading dishwasher. The center Glass Tray rests within the top rack. The top rack rests on tall wire loops in the corners of the bottom rack. This method of stacking the top rack on top of the bottom rack apparently began with the first GE dishwasher models produced around the middle 1930's. GE continued this design up to 1950. Subsequent replies to this thread will show the similarities and changes. So because the top rack rests on top of the bottom rack, the top rack could be placed in any of four positions with the glass tray orientated: (1) front, (2) left, (3) rear, (4) right. Having observed my own GE dishwashers with Plexiglas lids in place, it is very obvious that the center glass tray area of the upper rack did not get very much water lifted up from the impeller. The sides and corners of the top rack got much more water action. So, based on loading patterns that individual GE dishwasher owners used, if the gasses were not getting properly cleaned, perhaps the top rack might be rotated to one of the other three positions until the best results were observed. Why did very little water make it to the center glass tray in the top rack? The silverware basket sits right on top of the impeller. The amount of silverware utensils in the basket, would affect the amount of water that could get past and lifted high enough to reach all the way into an inverted glass tumbler. Around 1955, GE changed the rack configuration, redesigning the top rack eliminating the center section completely and redesigning the silverware basket plus raising it a little further above the impeller (see the forth page following this reply). Mike |
Post# 737580 , Reply# 9   2/25/2014 at 12:18 (3,711 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Post# 737581 , Reply# 10   2/25/2014 at 12:29 (3,711 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Here is the S-7 Mechanism Parts List. The models produced in 1948 and 1949 used this configuration. Note the top rack still rests on top of the loops of the bottom rack. Interesting observation here - the food particle filter screen (WD28X2) is shown with the impeller. Yet, I have never found a filter in any of the GE dishwashers in my collection. I believe they were such a nuisance, that GE dealers pulled them before installing the dishwashers in homes. |
Post# 737582 , Reply# 11   2/25/2014 at 12:35 (3,711 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Post# 737583 , Reply# 12   2/25/2014 at 12:44 (3,711 days old) by dishwashercrazy (West Peoria, IL)   |   | |
By the mid-1950's the top rack is totally redesigned. Also, a regular timer (item #91) is introduced to control start, stop, water fill and drain. The timer replaced the speed reducer controlled Cam and Cam Follower method of controlling the cycle. An external drain pump (item #88) was also introduced. |
Post# 737923 , Reply# 13   2/26/2014 at 19:46 (3,710 days old) by mopar65 (Almont MI)   |   | |
Post# 737957 , Reply# 14   2/27/2014 at 01:26 (3,709 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Post# 738047 , Reply# 15   2/27/2014 at 13:39 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738048 , Reply# 16   2/27/2014 at 13:39 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738049 , Reply# 17   2/27/2014 at 13:40 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738050 , Reply# 18   2/27/2014 at 13:41 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738051 , Reply# 19   2/27/2014 at 13:42 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738052 , Reply# 20   2/27/2014 at 13:43 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738053 , Reply# 21   2/27/2014 at 13:44 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738055 , Reply# 22   2/27/2014 at 13:45 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 738080 , Reply# 23   2/27/2014 at 15:01 (3,709 days old) by mopar65 (Almont MI)   |   | |
Post# 739035 , Reply# 24   3/3/2014 at 15:00 (3,705 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Anthony: The Model is SE120B The Serial Number begins with '5320' which translates to Build Year of 1953, 20th week, which translates to the week of May 20 (plus or minus). Disassemble and clean the pump carefully. If you haven't already, hook up a hose from the water valve to a faucet and test. If plugged, carefully disassemble and carefully clean the valve filter. The impeller is really in sad shape. And they are next to impossible to fine new. Generally, one needs to find a donor machine to get a replacement impeller. The S-10 Mechanism Parts Listing (above) is virtually the same as the S-11 Mechanism used on the SE120B models. I don't have the SE120B listing on paper; I only have it on microfiche. Mike |
Post# 739064 , Reply# 25   3/3/2014 at 16:49 (3,705 days old) by mopar65 (Almont MI)   |   | |
Post# 739336 , Reply# 26   3/4/2014 at 21:34 (3,703 days old) by mopar65 (Almont MI)   |   | |
Post# 739337 , Reply# 27   3/4/2014 at 21:52 (3,703 days old) by mopar65 (Almont MI)   |   | |
Post# 739393 , Reply# 28   3/5/2014 at 07:19 (3,703 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Congrats on the "Electric Sink" which came from my neighborhood.
Here's a link to some inof on my 56 GE dishwasher, the pump is built by Gorman-Rupp, and I sealed mine up with some small 1/4" inch O-rings on each end of the shaft. CLICK HERE TO GO TO akronman's LINK |
Post# 739991 , Reply# 29   3/7/2014 at 04:30 (3,701 days old) by mopar65 (Almont MI)   |   | |
