Thread Number: 51455
tub hitting cabinet when spin cycle ends. |
Post# 738394 , Reply# 2   2/28/2014 at 22:03 (3,680 days old) by Yogitunes (New Jersey)   |   | |
lubricate the brake assembly.....YES
lubricant on the belt............NO lubricant on the snubber.........NO the snubber is like a shock absorber, to keep the unit inside steady and not flopping around, and allows minimum movement of the tub assembly.... WD-40 is not really a lubricant, more of a water dispersant and de-greaser....it should wear away eventually.....then you may only want to add a few drops of Zoom Spout Oil to the brake only!.... |
Post# 742005 , Reply# 3   3/15/2014 at 00:15 (3,666 days old) by super32 (Blackstone Massachusetts)   |   | |
