Thread Number: 51566
Replacing control panel on newer Speed Queen |
Post# 739521 , Reply# 1   3/5/2014 at 15:47 (3,702 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Not an expert, but dont think so. AFAIK, the 542 has a whole different timer setup... |
Post# 739524 , Reply# 2   3/5/2014 at 15:59 (3,702 days old) by washman (o)   |   | |
a totally different timer. Also see my channel, I put up another vid of the Speed Queen carrying the freight. |
Post# 739569 , Reply# 4   3/5/2014 at 18:53 (3,702 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You would need a control panel, timer, cycle switch, one extra knob and a complete wiring harness, I would guess it would cost you around $200+ depending whether you can buy parts at retail or dealer cost. There is little functional advantage in doing the switch, as a dealer we sell the 412 ten to one compared to both the 432 and 542 combined, it will still be the same washer when you are done.
Now if someone really wants to upgrade their SQ washer I do have the florescent light assembly from an Amana TOL washer, it just screws on and you only have to connect two wires to make it work, I put one on my SQ FL washer a few years ago. I will sell the assembly for $70+shipping. John L. |
Post# 739611 , Reply# 6   3/5/2014 at 20:22 (3,702 days old) by chetlaham (United States)   |   | |
Post# 744988 , Reply# 8   3/25/2014 at 07:02 (3,683 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Will not hurt a thing, millions of TL washers have been made over the years where the user can change the speed at any time and also during the coerce of many washer cycles the timer also changes the motors speed while running.
Even on the GE FFs mechanical multi-speed clutch machines you can switch speeds all you want with no harm to the washer. |
