Thread Number: 51725
Miele W32445 front loader, load not dry after spin |
Post# 741156 , Reply# 1   3/11/2014 at 15:52 (3,692 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
The cause *may* be the carbon brushes (this model should not have a FU-drive). So i suspect worn carbonbrushes as this can cause such problems! |
Post# 741161 , Reply# 2   3/11/2014 at 16:35 (3,692 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 741176 , Reply# 5   3/11/2014 at 17:22 (3,692 days old) by mrboilwash (Munich,Germany)   |   | |
Don`t know the particular model, but usually there is a water reservoir between the pump and the drain hose which is used to seal the detergent recovery valve at the bottom of the outer drum by gravity from the water in the reservoir.
If something is wrong with this valve gray water might splash or seep back into the drum and result in a partially dripping wet load of clothes despite of a high final spin speed. This post was last edited 03/11/2014 at 17:43 |
Post# 741187 , Reply# 6   3/11/2014 at 18:29 (3,692 days old) by brisnat81 (Brisbane Australia)   |   | |
Being that this machine spins at 1600RPM, its highly unlikely that it has brushes. The Miele products that spin Faster than 1400RPM all have the professional brushless motor. |
Post# 741283 , Reply# 8   3/12/2014 at 03:49 (3,691 days old) by richnz (New Zealand)   |   | |
There is a hose that runs from the pump to the water inlet. It's small and it connects to a Y connector. Check that this is clear. Also check that the ball valve is not clogged and this can be released by undoing one screw and pulling down firmly. |
Post# 741328 , Reply# 10   3/12/2014 at 12:13 (3,691 days old) by kamrate ()   |   | |
@richnz Not sure what you mean when you say "the ball valve" to be honest. The hoses are all clear as best as I can tell. |
Post# 741354 , Reply# 11   3/12/2014 at 14:12 (3,691 days old) by ozzie908 (Lincoln UK)   |   | |
According to a google search of the number it does indeed have carbon brushes and as miele motors are known to wash when they do not spin.
For the cost of replacement brushes its surely a good idea to just try them? Austin CLICK HERE TO GO TO ozzie908's LINK |
Post# 741364 , Reply# 13   3/12/2014 at 14:48 (3,691 days old) by kamrate ()   |   | |
I can confirm that this smaller hose is NOT blocked. I took the top off and was able to loosen the hose, and there was no resistance when blowing into it down into the pump. |
Post# 741483 , Reply# 16   3/12/2014 at 22:43 (3,691 days old) by richnz (New Zealand)   |   | |
Sorry about the classy photos but here are the hoses I was referring to |
Post# 741484 , Reply# 17   3/12/2014 at 22:44 (3,691 days old) by richnz (New Zealand)   |   | |
You can see the ball-valve in the background |
Post# 741485 , Reply# 18   3/12/2014 at 22:46 (3,691 days old) by richnz (New Zealand)   |   | |
undo the top screw and pull downwards. Maybe there is a sock in there slowing the draining??? |
Post# 741516 , Reply# 20   3/13/2014 at 04:57 (3,690 days old) by mrboilwash (Munich,Germany)   |   | |
The reservoir for the ball valve I was reffering to is almost on top of the machine.
A faulty detergent recovery valve is only one posibillity but still my best guess. The link goes to the patent of the ball valve and the reservoir is #12 in the graphics. It`s just to give an impression of how much water "could" actually seep back into the drum. CLICK HERE TO GO TO mrboilwash's LINK |
Post# 741518 , Reply# 21   3/13/2014 at 05:38 (3,690 days old) by mrboilwash (Munich,Germany)   |   | |
A faulty ball valve is also quite easy to rule out without any disassembling at first.
If possible unload the washer immediately after the cycle is finished. Then check for the next few weeks for a tiny puddle of water in the drum before you load the clothes. This way you`ll recognize a possible problem even if it is only a periodic thing or if it takes a few hours for the water to seep back. |
