Thread Number: 5179
Oh so........... Brown! |
Post# 112310   2/27/2006 at 09:43 (6,631 days old) by jetaction (Minneapolis)   |   | |
Post# 112312 , Reply# 1   2/27/2006 at 09:45 (6,631 days old) by veg-o-matic (Baltimore, Hon!)   |   | |
Post# 112332 , Reply# 2   2/27/2006 at 10:53 (6,631 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 112363 , Reply# 3   2/27/2006 at 13:48 (6,631 days old) by tlee618 ()   |   | |
Hi Don, I had that same dishwasher and there was never a small utensil basket that came with mine, I am thinking that maybe it was something you could by as an extra. Terry |
Post# 112370 , Reply# 4   2/27/2006 at 14:14 (6,631 days old) by gyrafoam (Wytheville, VA)   |   | |
That looks great! Those were good old machines. |
Post# 112386 , Reply# 5   2/27/2006 at 15:52 (6,631 days old) by toggleswitch (New York City, NY)   |   | |
Post# 112444 , Reply# 6   2/27/2006 at 19:53 (6,630 days old) by appnut (TX)   |   | |
Don, as I've said, we had the built-in version of this at our weekend home. It did come with the avocado small items basket. It was kinda similar to the KA small items basket that came iwth superbas, but was totally squared off at the bottom rather than having the bottom slant up some from the center.
Post# 112534 , Reply# 7   2/28/2006 at 09:35 (6,630 days old) by jasonl (Cookeville, TN)   |   | |
What's that green washer(?) next to the DW? Looks like a Hitachi/GE portable. |
Post# 112627 , Reply# 8   2/28/2006 at 22:34 (6,629 days old) by jetaction (Minneapolis)   |   | |
Post# 113184 , Reply# 10   3/3/2006 at 19:11 (6,626 days old) by appnut (TX)   |   | |
Kevin, you guessed properly about the top rack. I'm not sure how I can explain how the buttons worked. Definitely not rocker. You depressed the bottom end of it to select a different cycle. That button then went down and was "down" all the way up almost to the top compared to the button parallel to it. The buttons for this were Rinse & Hold, Light Wash, Normal Wash, Sani-Wash. INcidentally, that roto top rack was adjustable to two heights for larger plates or taller glasses. If glasses were too tall, they'd bump the metal track that went form the middle to the back of the machine (used for sliding the rrack in & out) and thus once a glass hit that track, rotation would cease.
Post# 113228 , Reply# 11   3/3/2006 at 22:25 (6,626 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 113232 , Reply# 12   3/3/2006 at 22:59 (6,626 days old) by petek (Ontari ari ari O )   |   | |
Post# 113234 , Reply# 13   3/3/2006 at 23:10 (6,626 days old) by kevinpreston8 ()   |   | |
Is the Roto Rack driven by some water pressure, or simply at will by the spray of the arm? |
Post# 113248 , Reply# 14   3/4/2006 at 02:02 (6,626 days old) by appnut (TX)   |   | |
Kevin, picture this. On D&M dishwashers, you had a plastic tube that ran from the left back part of the tub up and over to an angle that me a tube that supplied waetr to the wawsh arm under the top rack. Well, with the kenmore that tube was modified some such that it was a real tube and had spray nozzle holes-one set shot up to wash the glasses and other stuff in the top rack, another set sprayed at an angle such that it caught the support ribs of the rotorack and caused it to turn by the force of the spray from those holes.
Post# 113360 , Reply# 15   3/4/2006 at 18:34 (6,625 days old) by kevinpreston8 ()   |   | |
Bob thanks for the explanation. My ancient unit spins its "roto rack" by virtue of the water splashing off the dishes below! |
Post# 113574 , Reply# 17   3/5/2006 at 21:11 (6,624 days old) by laundryboy (Orlando Florida & Moravia NY. )   |   | |
Post# 113598 , Reply# 18   3/6/2006 at 00:03 (6,624 days old) by appnut (TX)   |   | |
