Thread Number: 51943
Whirlpool Imperial Seventy washer needs a new pump? |
Post# 743498 , Reply# 1   3/20/2014 at 08:09 (3,661 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Nice washer - you're right about the performance, this is probably one of the best cleaning "large capacity" washers.
Here is pump on ebay for the belt-drive Whirlpool - Kenmore washers that might work. CLICK HERE TO GO TO gansky1's LINK on eBay |
Post# 743505 , Reply# 2   3/20/2014 at 08:29 (3,661 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
I think that model will use the 2 port water pump as it has the "magic clean filter", part # 350365. Ebay has several for sale.
CLICK HERE TO GO TO jeff_adelphi's LINK on eBay |
Post# 743525 , Reply# 3   3/20/2014 at 10:19 (3,661 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
I had a Kenmore 80 series, right around that vintage that developed the same problem. I was given a GE and I gave the Kenmore to my brother in law, thinking the pump was gone. The problem was over the years, the self cleaning filter was totally clogged. He simply disconected the filter and problem was solved.
Post# 743691 , Reply# 5   3/20/2014 at 19:47 (3,661 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These filters seldom failed if you used plenty of detergent, the reason they clogged was users mineraled up the machine, the mineral despots caused lint to get stuck and clog.
You should NEVER bypass the filter because it will cause the water pump to clog and fail. I serviced many washers where the filter had been bypassed and the pumps were jammed with lint and then they had to be replaced. |
