Thread Number: 52065
My new vintage Miele G 527 Automatic |
Post# 744647   3/23/2014 at 22:27 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744648 , Reply# 1   3/23/2014 at 22:28 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744649 , Reply# 2   3/23/2014 at 22:29 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744650 , Reply# 3   3/23/2014 at 22:30 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744651 , Reply# 4   3/23/2014 at 22:31 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744652 , Reply# 5   3/23/2014 at 22:32 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744653 , Reply# 6   3/23/2014 at 22:33 (3,679 days old) by mielerod69 (Australia)   |   | |
Post# 744766 , Reply# 9   3/24/2014 at 10:49 (3,678 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 744779 , Reply# 10   3/24/2014 at 13:06 (3,678 days old) by ozzie908 (Lincoln UK)   |   | |
Is there a second screw slot on the left side of the door that adjusts the water level ? Found one on a similar machine it was in a kitchen with poor water pressure and turning the screw made it stop cavitating which it had been doing for a long time the housekeeper used to throw a jug of water in and that was ok while standing near by its still going now I believe and I found out about the screws 14-15 years ago.
Brilliant machines real workhorse. Austin |
Post# 744844 , Reply# 11   3/24/2014 at 17:40 (3,678 days old) by mielerod69 (Australia)   |   | |
Thanks Foraloysius. I will use this for a while and then probably install my G 2834 SCi later. There are two switches on the left hand side, one to raise the water level if the incoming water pressure is low and the other to add a second interim rinse. These machines use 7 litres per fill. If memory serves me, I have an old brochure on this model that states the pump circulates 11,000 litres of water during the Universal programme.
Post# 745129 , Reply# 12   3/25/2014 at 18:37 (3,677 days old) by Dimitris (greece)   |   | |
Post# 745926 , Reply# 13   3/28/2014 at 20:33 (3,674 days old) by mielerod69 (Australia)   |   | |
Post# 745927 , Reply# 14   3/28/2014 at 20:34 (3,674 days old) by mielerod69 (Australia)   |   | |
Post# 746019 , Reply# 15   3/29/2014 at 10:22 (3,673 days old) by logixx (Germany)   |   | |
Post# 746094 , Reply# 16   3/29/2014 at 17:39 (3,673 days old) by mielerod69 (Australia)   |   | |
Post# 746231 , Reply# 17   3/30/2014 at 07:15 (3,672 days old) by logixx (Germany)   |   | |
600 watts? O_o
I have a service manual for the G500 Series dishwashers and most cycles are listed as around 60 minutes with hot water going in and the powerful Euro heater rating. Comparing that to today's energy efficient Miele dishwashers - even the Normal 55C cycle for daily use takes almost two hours. |
