Thread Number: 52272
Red GE Stove- Pensacola, FL |
Post# 746257   3/30/2014 at 10:01 (3,677 days old) by bluejay (Havre de Grace, MD)   |   | |
Nice looking GE stove in the sunshine state. CLICK HERE TO GO TO bluejay's LINK on Pensacola Craigslist |
Post# 746258 , Reply# 1   3/30/2014 at 10:04 (3,677 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 746291 , Reply# 2   3/30/2014 at 11:44 (3,677 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Abuse. |
Post# 746295 , Reply# 3   3/30/2014 at 12:03 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
May want this - it's a very rare range.
The burners were probably heated red-hot and left on after a pot was removed. Fortunately, they're still readily available and this model GE range does not have Sensi-Temp, simplifying burner replacement. However, I can see some issues that the seller's "very good condition" description just glosses over. Chief among them are some chips in the side panels, and unless I'm mistaken, a crack in the control panel glass. Burner trim rings appear to be original, meaning they're almost certainly due for replacement due to rust. I cannot tell much about the burner bowls, since they're covered with foil. If those are original aluminum ones, that's a plus. |
Post# 746306 , Reply# 4   3/30/2014 at 14:13 (3,677 days old) by appnut (TX)   |   | |
Post# 746308 , Reply# 6   3/30/2014 at 14:44 (3,677 days old) by rp2813 (Sannazay)   |   | |
Post# 746311 , Reply# 7   3/30/2014 at 14:53 (3,677 days old) by norgeway (mocksville n c )   |   | |
These are attached to the units I think , this color. came out in 61 I believe. |
Post# 746314 , Reply# 8   3/30/2014 at 15:08 (3,677 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The color is richer than it shows up in the photo. |
Post# 746320 , Reply# 9   3/30/2014 at 16:16 (3,677 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I am quite sure that this range had the Tilt-Lock surface units because the SensiTemp was constructed that way so the rings are separate. |
Post# 746326 , Reply# 10   3/30/2014 at 17:11 (3,677 days old) by pulltostart (Mobile, AL)   |   | |
I have corresponded with the seller since Friday about this and have tenative plans to travel south tomorrow and purchase it.
I did note the "clean" description with doubt, I see a lot of elbow grease and detailing ahead. I believe after studing and emailing that the sensi-temp unit has been replaced; and that's fine with me. The left rear burner does need replacing, I hope I don't find much more than that when I see it in person. lawrence |
Post# 746336 , Reply# 11   3/30/2014 at 17:21 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
"It actually does have a SensiTemp."
I'll take your word for it, because I'm not seeing any indications of that in the burners themselves, and the resolution isn't high enough to see the indicia on the control panel. As Lawrence says, if it ever had Sensi-Temp, the burner seems to have been replaced. |
Post# 746338 , Reply# 12   3/30/2014 at 17:26 (3,677 days old) by pulltostart (Mobile, AL)   |   | |
This model was equipped with Sensi-Temp when manufactured. The controls for the left-front read "Grille, 8 Inch, 6 Inch, 4 Inch, Off" and the dial to the left of the clock/timer is the thermostat for the unit. However, the seller told me that that burner says "Calrod" in the center - not a sensor. Leads me to believe the unit was replaced along with the pushbutton assembly and now simply functions the same as the right rear burner. Conjecture on my part based on the photos and what the seller told me.
lawrence |
Post# 746339 , Reply# 13   3/30/2014 at 17:34 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Looking at the white range on eBay, the res is high enough to see "Sensi Temp" on the control panel indicia and on the far-left bank of pushbuttons.
Learn something new every day.... BTW, the eBay range is schweet. Super clean, original aluminum burner bowls, and the Sensi-Temp sensor is present on the left-front burner. Someone's gonna be happy. |
Post# 746343 , Reply# 14   3/30/2014 at 17:42 (3,677 days old) by pulltostart (Mobile, AL)   |   | |
Post# 746345 , Reply# 15   3/30/2014 at 17:48 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 746381 , Reply# 16   3/30/2014 at 20:24 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 746385 , Reply# 17   3/30/2014 at 20:29 (3,677 days old) by moparguy (Virginia)   |   | |
Good luck on your travels and purchase tomorrow! That is a really neat and rare color on a very nice stove! |
Post# 746386 , Reply# 18   3/30/2014 at 20:29 (3,677 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 746404 , Reply# 19   3/30/2014 at 21:16 (3,677 days old) by bajaespuma (Connecticut)   |   | |
Post# 746405 , Reply# 20   3/30/2014 at 21:18 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 746409 , Reply# 21   3/30/2014 at 21:29 (3,677 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 746467 , Reply# 23   3/31/2014 at 02:01 (3,677 days old) by rp2813 (Sannazay)   |   | |
Post# 746479 , Reply# 24   3/31/2014 at 05:50 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 746480 , Reply# 25   3/31/2014 at 05:54 (3,677 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
It occurs to me that this model is an early appearance of the "upswept top" that became standard on GE ranges. For a long time, GE constructed the control panels of most models in a separate housing attached to the cooktop, with the result that there was a seam where the control panel housing met the cooktop - just where it would catch the maximum amount of grease and schmutz. This situation lasted through '71, with GE finally making a move toward a one-piece cooktop/housing assembly on most models in '72. My J 370, built in that year, has the one-piece "upswept" design.
Post# 746494 , Reply# 26   3/31/2014 at 06:58 (3,677 days old) by pulltostart (Mobile, AL)   |   | |
Post# 746501 , Reply# 27   3/31/2014 at 07:27 (3,677 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 746505 , Reply# 28   3/31/2014 at 07:38 (3,677 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I love this color! Well, in pictures anyway, I've not seen it in person. There was another GE red range in Shawnee, KS a while back on ebay, here's the AW thread. It sold for $20.50, the auction and pics can still be seen on ebay. I had that KS range on my watchlist and it was all I could do at the time to not bid on it. What a looker!
Good for you, Lawrence, I'm glad you're going after it. The rarer the color, the more exciting it is and then red, from GE!
In my superserchalator search, I also came upon a GE mixer in the same color. See that thread here.
Post# 746516 , Reply# 30   3/31/2014 at 08:12 (3,677 days old) by oldskool (Kansas City, MO)   |   | |
Lawrence - happy for you. I'm sure you'll enjoy your new Red GE Stove!
John |
Post# 746521 , Reply# 31   3/31/2014 at 08:53 (3,677 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 746525 , Reply# 32   3/31/2014 at 09:26 (3,677 days old) by bluejay (Havre de Grace, MD)   |   | |
Post# 746565 , Reply# 34   3/31/2014 at 14:16 (3,676 days old) by norgeway (mocksville n c )   |   | |
A Turquoise one.. CLICK HERE TO GO TO norgeway's LINK on Appleton Craigslist |
Post# 746567 , Reply# 35   3/31/2014 at 14:18 (3,676 days old) by norgeway (mocksville n c )   |   | |
Ad for it! RED...NOT ORANGE! LOL CLICK HERE TO GO TO norgeway's LINK on eBay |
Post# 746594 , Reply# 36   3/31/2014 at 17:38 (3,676 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 747140 , Reply# 37   4/2/2014 at 17:26 (3,674 days old) by pulltostart (Mobile, AL)   |   | |
My brother and I drove over to Pensacola yesterday morning and bought the red GE. The woman who was selling it had owned the range for something 40 years and I thought she was going to cry when she started telling me about it. She purchased the range when it was about 10 years old from the original owner, when that owner moved into a retirement/nursing home. The Pensacola owner has a passion for red.
The stove needs work. She said that they cleaned it up before posting the ad, but it has a long way to go. I've cleaned on the oven and some of the cabinet but the rest will have to wait as I'm heading back to Atlanta tomorrow. I believe all 4 of the burners could stand to be replaced, each for a different reason. And I will have to take everything apart on the backsplash to remove the grease that's built up. But "Ol' Red" is in my Mobile house and will be waiting for me when I come back next time. There are numerous chips in the porcelain - any suggestions as to how to find a suitable touch-up paint in this color??? lawrence |
Post# 747142 , Reply# 38   4/2/2014 at 17:29 (3,674 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 747172 , Reply# 39   4/2/2014 at 20:14 (3,674 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
First, congratulations on nabbing the Pensacola range!
I have a question, though: Is the lens of the clock/control center cracked, or is that a stain of some kind? There are porcelain touch-up options that go beyond mere touch-up paint. Acrylic fillers can bring the void of a chip up to the level of the surrounding surface, and then careful spraying of a matching paint over the acrylic can result in a very hard-to-detect repair. Antique dealers are using this idea a lot with chipped porcelain dishes, vases and figurines. Here's a link to a page offering an acrylic porcelain repair system, about $30: CLICK HERE TO GO TO danemodsandy's LINK |
Post# 747262 , Reply# 40   4/3/2014 at 07:27 (3,674 days old) by pulltostart (Mobile, AL)   |   | |
Post# 747270 , Reply# 41   4/3/2014 at 09:05 (3,674 days old) by Tomturbomatic (Beltsville, MD)   |   | |
What about the harvest gold GE you bought? |
Post# 747333 , Reply# 42   4/3/2014 at 15:02 (3,673 days old) by pulltostart (Mobile, AL)   |   | |
I will post it on CL and sell. It cleaned up well enough, but I was having difficulty "embracing" the color. There is some internal signs of wear in the oven. It looks like someone either cleaned the h*ll out out the oven or baked/broiled a LOT. The liner for the door is warped and the porcelain is cracked, the same condition exists on the floor of the oven. It does look much better after several days of elbow grease, though.
lawrence |
Post# 747369 , Reply# 43   4/3/2014 at 18:01 (3,673 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
I'm sorry that glass is cracked, but everything turns up sooner or later, so we'll all keep our eyes peeled.
My J 370's control panel glass is not reverse-printed, either. It has held up fine over the course of forty-two years, but then I don't think it was cleaned much during its last few years with the former owner. And it obviously had good care for much of its working life. Sounds to me like the Pensacola lady might have had some favored scratch pad she used on everything. A lot of people do. |
Post# 747371 , Reply# 44   4/3/2014 at 18:04 (3,673 days old) by pulltostart (Mobile, AL)   |   | |
Post# 747393 , Reply# 45   4/3/2014 at 19:55 (3,673 days old) by fisherpaykel (BC Canada)   |   | |
I don't know GE's name but Belanger or Belanger-Tappan from Quebec called their's POPPY RED IIRC. |
Post# 747487 , Reply# 46   4/4/2014 at 06:05 (3,673 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
On my J 370, the control panel indicia appear to have been silk-screened in glass frit and then fired on. They would hold up to any kind of normal cleaning.
You could definitely wear them away and damage them with use of a scratch pad, though, and a lot of people have no judgment whatsoever about those things. I've seen new stainless sinks with Kurly Kate damage. |
