I have had a recent problem with my Hobart kitchenAide Kds 19, I traced it to a bad sani heat thermo switch. Does anyone know of a vendor / source for a B241268 kit
The thermostat you are looking for was changed to 4162595 and is most likely no longer available. You can search and see if you can find one, but I do believe that I have one of those in the attic treasure trove.
I will check and advise later when I get home from work.
Steve
